Question about Kenmore 700 sq. in. Cooking Area Gas Grill 14116325
Do i need to cover the burner and drip guard over with lava rocks
I just replaced the burner and drip guard im my gas grill how much lava rock do i need?
  • 4,059 Answers
So you don't have a lower rack for the rock to set on? Mine did and you just have one layer covering the entire surface.
Posted on Aug 02, 2009
I have thermos quick set gas grill--are the lava rocks supposed to cover the burner cover
They should cover the tray above the burner so the burner can heat them .
Apr 20, 2012 | Thermos Quick Set Gas Grill 4000
Do the weber gas grills use lava rock?.
Short answer ...No. They use a flame tamer or flavorizer (the tent like things over top of the burners. Lava rock, would cause uneven heating.
May 29, 2011 | Weber Genesis Silver A Grill
I went to turn on my gas grill and opened the valve to the propane tank which is indicating "full". Although when I turn the knob(s) to start the grill no propane travels trough the hoses???
its probably not the hoses its probably your burner are clogged with drippings and need to be replaced or just move the lava rocks of off them and tap on the burners the dispense the propane, try that.
Jul 07, 2010 | Garden
Need radiant trays & lava rock replacements for GE Monogram 24" grill model # ZGG24L20BSS Natural Gas.
The tray and lava-rock is available at most larger retail hardware stores. You may not find the exact tray for your model, just get one of equal size.
Jun 05, 2010 | GE Monogram ZGG24L20BSS Grill
Use of Charcoal or Lava Rocks in the Char Broil Patio Caddie?
LP grills are designed to use lava rock ONLY. Charcoal will clog the burners.
May 16, 2010 | Char-Broil Patio Caddie 4654870 (LP) Grill
How do you replace a burner on a ducane gas grill
Hello : Here are two solutions , just look which one of them is the most helpful .
  1. Turn off the gas supply and bleed the lines leading to the grill. Remove the gas tank if possible.
  2. Open the grill and remove the grates. In some cases you will need to
    detach the hoses from under the grill using simple hand tools. Other grills may have simple "float in" style of burner. These styles look as if the tubes from the burner leading to the gas supply lines simply "float" into each other. Look for clamps of holders that may need to be removed.
  3. Remove the damaged burner and remove from grill. Take a moment to inspect the other burners and any other hoses in case you need to replace more than one piece. Place the burner in a plastic bag and take it to the home store so you can get the exact parts you need. This removes all guess work.
  4. Before replacing the burner/burners etc, take a moment to clean any material, grease etc from the bottom of the grill. Replace the burners and hoses as needed. Check the connections before reconnecting the gas supply. Turn the gas on and start to flow of gas to the burners without lighting the grill. Make sure the flow is working. Be sure to turn the gas off, let the fuel dissipate before lighting.
  5. With everything working, fire up the grill and enjoy.
Or try these help here :
  1. Turn off the gas supply valve on the tank. Remove the fuel line from the fuel tank by turning the connection nut counter-clockwise with your hand.
  2. Open the Char-Broil gas grill and remove the main cooking grate. You do not need to remove the upper warming racks to change the burners.
  3. Remove the lava rocks from the grill and pull the rock grate out. Unhook the flame spreader from each end where the spreader attaches to the inside body of the grill. The spreader is the angled piece that sits over the burner.
  4. Locate the cotter pin that secures the front of the burner to the grill body. Remove the cotter pin with a pair of needle nose pliers. Lift the burner up and pull the burner venturi tubes out of the gas valve.
  5. Set the new burner inside the grill with the venturi tubes inside the gas valve opening. Install the cotter pin to secure the burner to the grill body. Place the flame spreader back inside the grill and hook the ends to the grill body.
  6. Place the rock grate, lava rocks and cooking grate back inside the grill. Reattach the fuel line to the fuel tank.
Here you need Needle nose pliers.
Please report me which one helped the most .
good luck .
and rate if useful please !
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Feb 20, 2010 | Ducane 30400040 Stainless Steel Grill
Charcoal in a gas grill...Wassup with that?
Well are they lava rocks or charcoal? The Master Flame series is supposed to have lava rocks. If what you see is charcoal, remove it and replace with the lava rocks. You can order the rocks from Char-Broil's website.
Sep 06, 2009 | Char-Broil CharBroil Master Flame Gas...
What is the reason why I can't use lava rocks and a grate in any propane gas grill?
who said you cant?????????? use whatever the hell you want to....... ceramic or lava.... just make sure you keep the flame down to about medium and give those steaks a good two days to marinade and call me when your gonna heve em ready!!!!!!!!!!!! need a good marinade recipe??? garthayling@hotmail.com shoot me an email and i;ll hook you up with the best ive tried.... good luck
Jul 15, 2009 | Grilling
I have no even heat on my gas grill across the top
hello, lava rocks should be evenly spread apart but no real certain way i'ld check out your burners to see if there the cause of the gas supply to each burner
Mar 29, 2009 | Char-Broil CharBroil Master Flame Gas...
Kenmore 700 sq. in. Cooking Area Gas Grill 14116325 Logo
232 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
paulcarew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
