Question about Refrigerators
Ice cubes leave wierd flaky sediment in glass as the melt. What is causing this? Just replaced filter.
Sounds like hard water deposits. Naturally occuring minerals like Lime and Calcium react in just such a way. My guess is that you livein a rural area and have well water? Just so you know, the options are water softner/filter system or accept the less costly less appealing fact that it wont hurt you.
Posted on Aug 02, 2009
White sed iment from ice cubes
This is limescale as you must live in a hard water area, and I expect you also get scale in your kettle. You need to descale the ice-maker if you have one, or if it is from a mains water tap, you can use a under-sink filter, a Brita Jug, or buy bottled water to make ice. The calcium is actually fairly good for you.
Aug 29, 2017 | Dishwashers
How to get rid of the sediment at the bottom of my glass from the ice
The sediment is the result of the minerals in your tap water precipitating to the bottom of the glass after the drink has sat for awhile. The minerals in the ice cause you ice to be cloudy and not clear. The only way to reduce or eliminate the sediment is to filter the water going to your ice maker and water dispenser.
Sep 27, 2014 | LG LRBN20510WW Bottom Freezer Refrigerator
Ice maker inside kitchen aid fridge not making full cubes
Items to check would be ,
1 Is the filter restricted with sediment in the water?
indicator would be water flow decreased thru door dispenser.
2 Is the tap a line (if used) restricted with mineral deposites where the sleeve pierces the water pipe.
3 is the valve itself restricted with sediment due to not using a filter?
4 a kinked water line (copper) or pinched plastic line could also cause this problem.
eliminate each and you should find the problem.
Jun 17, 2014 | KitchenAid Superba Architect KSCS25INSS...
My whirlpool GS6NBEXR refrigerator ice cube maker leaves slimey, flaky residue at the bottom of my glass. What can I do?
Diana, if I understand you ok, the ice you put in the glass leaves slimy residue. So that slimy stuff has to be in the ice cube. Well remove the the ice maker unit and thoroughly clean this ice holder and throw away the ice cubes in the kitchen sink and see if leaves slimy stuff. As for slimy stuff, while the unit is out, check any leaks etc. BTW any smell?
Jan 06, 2014 | Whirlpool GS6NBEXR Side by Side...
I have slimey, flaky sediment at the bottom of my glass of ice water. The water side is clear. I have a Whirlpool refrigerator with filter at bottom of freezer side. What can I do?
Your ice maker has a type of mold in it. Dump the ice turn off the water to the ice maker and let the ice maker clear the ice in it. Then get a spray bottle, put a little laundry liquid bleach and water in it and spray the tray where the ice cubes are made. . Let it sit for 10 or so minutes.then turn back on the water and let the ice maker go thru several cycles, dump that ice and then you're good to go.
Jan 06, 2014 | Whirlpool Refrigerators
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
Filtered water after heated to make tea looks like mud
I dout it's your refrigerator causing the sediments and discoloration. Cooling the water is cause separation of suspended solids, but one would think your filter would handle that problem. Check the filter to ensure it is seated properly and not bypassing. Inspect the filter for decomposition ( coming apart) I've seen filters installed with the paper wrapping not removed. :-) Now that will cloud things up and provide a great deal of floaters.
Jun 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
Sediment at the bottom of my glass of ice water
The sediment is condensed minerals. Applying a filter should fix that problem.
Aug 31, 2009 | Refrigerators
Ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Apr 12, 2008 | Refrigerators
Refrigerators Logo
949 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
