Re: The auto convergence setting is not in the setup menu
The ITC222 convergence option missing repair kit under RCA repair kits will fix that issue. The kit contains the parts and detailed instructions. heres where to get the kit. http://www.tvrepairworld.com/
If the auto convergence feature is still listted under the setup menu then you need a convergence power supply board. If the auto convergence feature is no longer listed under the setup menu then you just need a repair kit. You can get either one from www.tvrepairworld.com
sounds like the auto convergence option has disappeared from the set up menu. Press menu and scroll to setup and then enter setup menu and see if the auto convergence is still listed there or has it disappeared?
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
The Auto convergence feature listed under the setup menu will do it automatically. A common problem is the auto convergence feature will disappear from the setup menu. If yours has disappeared there is the convergence option missing repair kit from www.tvrepairworld.com will solve the issue.
Press menu on the remote then scroll down to setup then enter setup. The auto convergence feature is listed there which will reset it automatically. If auto convergence disappeared from the setup menu then you will need the RCA convergence option missing repair kit from www.tvrepairworld.com which does contain the instructions.
if you need to know where the convergence settings are you click menu then setup and then convergence. I have the same tv as you and the picture looks like its 3d with red and green and the words on menu are doubled and I tried auto converge and it didnt work. If you figure it out let me know. it also might be a fuse.
Convergence should be showing on Menu. Hit menu then go to setup you should see it listed their.
Heres How to Enter Service Menu for alinement of
convergence BUT I MUST WARN YOU be very carefull of adjustments in wrong alinement. With TV turned off PRESS and HOLD Both CH- and VOL- release when set comes on Now you should be in Teachician Service Menu there you should be able to Do convergence alinement and set Auto convergence.
Press your MENU button on the remote. Move to SETUP and press OK. Then choose Convergence. You should wait until your TV has been on for at least 1 hour before you run the auto convergence. Once the auto convergence has run, you can do your own fine tuning. There will be separate adjustments for Red convergence and Blue convergence. You will use the arrow keys to line up two sets of lines. The instructions will show up on the screen. Good luck, and I hope this takes care of your issue.
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Go to menu , then go to setup look for convergence in menu if it is not on the menu then fuseFL231 is bad replace ,then convergence should return back on menu press auto convergence and set should be back to normal.
