Question about Acer Aspire One Netbook 8.9" Notebook
Nothing happens Computer power on led comes on cap, numlock, fan is on. nothing on screen not even bios. Have seen many reports of similar model doing exactly the same. Acer support only wants to go thru basic troubleshooting over and over again.
  • seth veloso May 11, 2010
    I am not sure where you are in trouble shooting or if your machine is posting but maybe try an external monitor to check your lcd display and inverter. seth
  • 36 Answers
If you still have warranty on it, I would send it in for repair. If that's not an option for you, could you tell us if there's any kind of beep pattern?
In this situation I would normally suggest checking to make sure that the memory is seated properly. However on this netbook (I'm writing this from an Acer Aspire One right now) it would require taking it almost completely apart, as the memory resides on the bottom of the motherboard (nice design there, Acer! :-/ ).
Posted on Aug 02, 2009
My fujitsu laptop won't turn on.
If the cooling fan comes on and nothing else happens, it could be a GPU issue and be in need of reballing due to overheating.
Mar 03, 2014 | Computers & Internet
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
Hello. i have a problem whit my dell 1525 pp29l model.it wont boot up.when i press power button the power led stays on, and the scroll lock and numlock led flashes continuosly and nothing on the screen.i...
If it cannot finish POST then you have a mother board problem.
You state you reset the BIOS. Can you get to the BIOS menu? If you can then the problem is not motherboard errors but hard drive boot sector problems, depending on OS used.
If the BIOS has been updated, then it is possibly an incorrect version or corrupt.
If you can reflow the soldering, remove the BIOS chip and fit a known good one. That should fix your problem.
Hope this helps.
Nov 23, 2010 | Dell Inspiron 1525 Notebook
I've got an Intel server entry board S875WP1-E and I've set the BIOS how I need it. Now that the jumper's been put back to normal operation there seems to be no boot up action from the board. The...
While the power is off at the wall. remove the BIOS battery for about a min, then reinstall in the correct orientation. Power on at the wall socket and turn on. Was the board working before you flashed the BIOS?
It is possible that the BIOS is now currupt and therefore doesn't work go to www.badflash.com for more information.
They may be able to replace your BIOS chip.
Your timeous rating of this solution is much apperciated.
Thanks
Nov 01, 2010 | Intel Server Board S875WP1-E Motherboard
Toshiba satellite m35x-s114 boots to the toshiba screen then doesn't do anything else. Even with the f2 or f12 option nothing happens. I hear the fan (I think it is the fan) then no sound at all. I have to...
Try getting to the bios screen, if you can get to the bios screen then I would imagine the hard drive has failed. If it is hanging up at the toshiba splash screen and not allowing BIOS access, then I would lean toward a motherboard failure. Are you attempting a boot from the windows disc?, is that why you are trying F12? I have seen my share of these Toshiba M35's just give the Toshiba splash screen when there has been a motherboard issue. Changing out the main board will fix this particular problem. I had not found another solution for it.
Nov 27, 2009 | Toshiba Satellite M35X-S114 Notebook
My computer won't start.
check if the hard drive led is on so its the vid card if not its your motherboard because the fans are still running and its mean that the cpu is working but no activity
Jul 05, 2009 | Computers & Internet
When I hit power button on computer, power light doesn't come on...and the fan kicks on, but nothing else happens. nothing shows up on monitor except the test screen with 3 colors...the computer doesn't...
THis sounds like a power supply issue.. I had a similar issue with mine. my fan would kick on for about 2 seconds then shut off.
Hope that helps
Ciza
Oct 29, 2008 | Gateway (4000274) Motherboard
WYSE S10 Power up problem
Replacing C38 will fix the problem. It's a Lytics SMD Capacitor 47uF/10.3V.
Oct 26, 2007 | WYSE Winterm S30 Network Terminal
Acer Aspire One Netbook 8.9" Notebook Logo
142 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
