I have my pc hooked up through HDMI to the TV but the sound through red/white AV jacks it was working but now the TV thinks the sound is comming through the HDMI and i lost sound
  • wylde328 Aug 02, 2009
    sadly the HDMI is from the video card and the AV jack are from the sound card so i dont think that will help, thanks for giving it a shot
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, please postback with the brand and model number of the TV. Additionally, confirm that the sound is present on the green jacks of the computer either with a headset / headphones or external speaker.
In some TV models, the sound could be assigned and not necessarily with the HDMI.
Good luck and thank you for asking FixYa.
Posted on Aug 02, 2009
  • 336 Answers
Hi then,
Then just remove the red white audio cables. You don't need then since audio and video are alreadi in the HDMI. Just canfigure you conputer to out the audio at HDMI.
Regards,
Jeep Brainy
How do you connect a ps3 to a Emerson 32" TV, with yellow, white, and red cords
your yellow is the video in, white audio left, red audio right.
Feb 25, 2018 | Emerson Televison & Video
No signal fromdvd player video 1 (av)
yellow is video and red and white are audio you a get by with one audio. i think you are missing your video cable you can get by with two cables just use the white cable as a yellow and plug it into the yellow dvd plug and tv yellow plug and the red will stay hooked up for sound ( you wont have stereo but it should work)
Aug 05, 2012 | Audio Players & Recorders
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
Jacks show in black and white
You need component output on your Wi. You should have 2 AV jacks on your TV. I am guessing you have a red,white ,and yellow for your WI? That is made to hook up in the AV and NOT the component.If you have red,green,and blue? You might just have a bad cable,that is why it is in B&W. Or hook your Wi to your suround sound AV input if it has one. It is hard to give you all the answers with the info you provided.
But this is a educated guess. hope it helps. Todd
P.S. Be carefull with your controlers, SEVERAL accidents of them hitting the TV and breaking the screen. Play nice. :)
Jan 15, 2010 | Samsung UN55B6000 54.6 in. LCD HDTV
Cant get my tv to display my dvd player.when i hook the jacks to tv it doesnt work,the jacks are red,white and yellow
look at the point where you are trying to put the plugs into the tv are you matching colours if so are you sure its an input .?? ..... the easiest way is to use the inputs at the front of the tv(if it has one) and change it through your AV channels (hopefully you knew to chage to av?
Dec 15, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
I cannot get my PC sound to play through my Samsung LE32457A HDTV
I hope 3.5mm to twin phono would have plugged in headphone jack of PC to get sound for TV, right?
Reduce PC volume level up to zero and increase it very little bit to get sound in TV.
TV is getting excessive sound level from headphone jack and causing mute circuit to activate to avoid any internal damage.
Sep 26, 2009 | Samsung LE32A457 32 in. LCD TV
My PS3 does not show a picture wene it is hooked up with AV cables it just has sound but wene I plug in a HDMI cable sound and picture works. How can I switch it back to AV cables? I know there is a...
YES,ON YOUR TV GO TO CHANNEL 0 THEN DOWN ONCE AV CABLES ARE HOOKED UP,SOMETIMES ITSCH.69 JUST KEEP TRIN AND IT WILL POP UP,MAKE SURE RED,YELLOW,WHITE ARE IN RIGHT HOLES ...RED IS PIC. WH.SOUND
Jul 15, 2009 | Sony Playstation 3 (PS3) Console
Hook it up to the tv
If your hooking it directly to the tv depending on how old the tv is use one of the inputs. Hook the two red and white to red and white and the yellow to the video in input. If it's an older tv you will need whats called an rhf adapter. Hook your color codes together and use a cable cord to go from the antenna out to the tv's uhf input. I hope this information was helpful........... : )
May 10, 2009 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
