My Mum`s TV didn`t work.She `ve got only lock on the screen.She lost manual for her TV -HELP!!!!
  • 1 more comment
  • ha_blach Aug 07, 2009
    Hi there
    The situation with the TV is as follows. When the TV is turned on, a blue screen with a big red lock on the left top corner appears of the screen and the unit does not accept any input at all apart from the on/off button on the remote. The code that You've provided did nothing as I can not access the menu. I've tried turning the set off power for 24 hrs and that changed nothing. I have also followed Your instructions and nothing worked. Before I take it to the service centre, I wonder if there is a master reset button somewhere or a command that will allow the TV to be operated again. I did not set any parental lockdown, nor did i set any password on the unit.
    Please help.
  • ha_blach Aug 11, 2009
    Hi there
    The TV in question is a TV/DVD combo made by TEVION, model number TEV2184. I have the original remote control an the user manual.
    As written earlier, the unit is lockout, that is when turned on by either the remote or through the main switch a blue screen appears with a red lock in the left upper corner. No other functions on neither the front panel nor the remote work except the off button. There is no disc inserted, but loading one also makes no difference.
    I have tried to enter the code as You have suggested, but there was no response.
    I have also removed the main power cord from mains and left the unit off for 48 hrs. When connected back, there was no change.
    Before taking the TV into service, I want to make sure that there really is not some simple solution to resolve this.
    Looking forward to Your help
    On 2009-08-07, at 16:05, FixYa.com wrote:
    Dear ha_blach,
    Benimur has asked you to clarify your question to best assist with your My Mum`s TV didn`t work.She problem:
    Hi and welcome to FixYa, Initially, please postback with the brand and model number. Additionally, pls confirm that the original remote is still available and functional. Good luck and thank you for using FixYa.
    Click here to respond to the request.
    Regards,
    The FixYa Team
  • ha_blach Aug 13, 2009
    It`s TEV 2184-serial no xxxx-other no . 0511TEV21840902
    Sergeant:
    Novelist:
  • 198 Answers
  • 15,935 Answers
A model number is required to look up the unlock procedure and/or supply a manual.
Thanks!!
Posted on Aug 12, 2009
    Brigadier General:
  • 6,966 Answers
Posted on Aug 07, 2009
  • Louie  Role
    Louie Role Aug 12, 2009
    Appreciate your postback and additional information of the unit being a Tevio TEV-2184.
    Unfortunately, there is limited technical support I can share as this
    particular model is only available in UK (Europe) and Australia.
    Other than echo what was posted on the parental lock removal, there is
    no other easy user doable action. If the lock removal would not
    operate, them I am afraid that the services of an authorized service
    center is the only course of action left.
    Is there a way you can share the owner's manual?
    President:
  • 1,462 Answers
It sounds like someone set your parental controls up, you will need the password or to have it reset ..
STEP !:
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
STEP 2:
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
STEP 3:
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
STEP 4:
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV
STEP 5:
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Aug 02, 2009
Venturer Tv to Sky
It sounds like your TV is on the wrong input. Look for a button that says input or source. Depending on the TV this will either provide an onscreen menu to select an input or it will simply scroll through the inputs. Turn on the Sky box and run through the inputs until you see something that looks like your Sky Box.
Jul 26, 2013 | Televison & Video
My TV has a blue screen that say's lock
Just press and hold.the volume -ve and channel +ve button on the tv panel.
Jun 30, 2013 | Coby TFTV1703 17 in. LCD Television
I have a goodmans anologue tv in my bedroom I've
Refer its service manual and make a factory reset to it. To downlaod the service manual, google it with its brand name. I don't think there will ba a free download site for this brand TV. All download sites will be paid.
Apr 27, 2012 | Televison & Video
Hi I can't figure out how to get my N64 to work on my samsung flatscreen. My friend showed how to do it a while back but now i've forgotten. I've been told I need a scart cable but I...
Whoever told you you need a scart cable is wrong, The N64 is an old console therefore requires you to plug it in via a standard ariel port. You then should turn you N64 on and search for new channels using your TV menus to either automatically search for them or you can tune your tv manually. either way you will probably need to fine tune afterwards. If you need more help please e-mail me at garleet@hotmail.co.uk
Aug 11, 2011 | Nintendo Video Game Consoles & Games
I have a new pioneer RSM400DV mini system the problem is..every I watch a dvd. i saw my tv screen is black and white. please help me..
You can find the manual here in case you lost it or something:
http://www.pioneer-latin.com/es/soporte/manuales-usuario/
I have this system and I've no problems at all with it.
Feb 24, 2011 | Pioneer Televison & Video
How does my mum reinstall this dvd on a new tv she has lost her instruction manual and i am attempting to help her over the phone!
Advd player does not need tuning , simpley connect red white and yellow RCA leads from the back of your DVD to AV... input of tour TV use TV remote to select the same AV source eg AV1 AV2
Apr 21, 2009 | Yahoo YDP305 DVD Player
Blue screen with lock
If you push and hold down the display button the lock on the blue sceen will come off.
Jan 26, 2007 | Jensen TS2050J 20" TV
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
