SOURCE: windows. file missing or corrupt system32 config
If you're running XP, boot to the XP cd, if available (if not, mail me and I can send you a dell XP disc)
Pass the first repair opportunity, press f8, then it should allow you to do a windows repair. Do that. You will keep all your files, but windows will be completely reloaded. Will need to get updates, but that's it.
Good luck
SOURCE: compac presario 1500
You need to reboot using the first disc in the series. Make sure that the AC adapter is plugged in, and check your bios settings and disable any power managment settings, in order to prevent the machine from going into standby, sleep, etc.
You should be able to make it through the entire series. If you can't, you may need to contact HP for a new set of discs, or if you have an HP authorized service provider, such as a Staples, Best Buy, etc; they can usually get the CDs a lot faster, and usually at the same cost, or maybe a little higher.
SOURCE: Windows doesn't recognize recovery partition after os reinstall
The issue you are having involves using multiple systems,...If your emachine came with vistan and you installed xp, you voided your warranty status...However remove your dual boot and stick to vista if you wanna keep your restore partition working properly.....On a side note theres usually conflict with running OEM OS's on dual boot...typically it doesnt work and if it does it doesnt work like you want it to! so here is what you can do..Call Emachine up and fib to them a bit (just alittle) tell them that you cought a nasty bug and it messed with your restore partition and now you cant restore your pc....request the factory programing discs (if you ask nicely they'll hook you up 99.99% of the time) you get the discs so you can reprogram the pc to factory spec if you ever wanted to. Now use a retail version of vista and a retail version of xp. and create your dual boot, feel free to remove your restore partition if you want (cause you have the factory programing discs if you wanna go back to stock stuff YAY) I hope this helps!
Testimonial: "Highly knowledgeable and an awesome guy for taking his time to share his expertise with the pc community. Thanks again!!!"
SOURCE: Compaq Presario m200 Laptop system recovery
buy or download a windows disk. insert it and format the partition and install a fresh copy
