Question about Whirlpool WFW8400TB Front Load Washer
Water won't come into washer. machine cycle works fine other wise.
    Problem Solver:
  • 6 Answers
Before assuming the problem is with the machine, shut off your water to the machine; remove the water inlet hoses from the machine and aim them into the tub or a bucket, carefully open the water inlet valves and observe water flow through the inlet hoses. Sometimes debris from the water system can clog the washer hose screen(s).
Posted on Aug 04, 2009
How do I get cold water only to run in my W10550314B washer? Just purchased 4 days ago
Newer washers only way to run cold water only would be to use a Y adapter off cold water supply and hook cold to both hot & cold to washer other wise some cycles will not work
Mar 24, 2015 | Kenmore Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
Maytag_lse7804ace: washer won't fill with water. If I fill it by hand, the cycle works fine (until it gets to the rinse cycle, when it won't fill again).
Hello John,
The most probable reason the washer is not filling is because of a blown fuse that is part of the lid switch asm. By UNPLUGGING THE WASHER and removing the 2 INNER screws on the the control panel and the control panel can be rotated down to see the fuse in the lid switch asm. Here is where the fuse is on the switch asm. its circled in red 11_4_2011_1_39_54_am.jpg
Nov 03, 2011 | Washing Machines
I have a Kenmore Elite He3. It won't complete any wash cycle without stopping and displaying HF. I can restart it but it continues restarts the wash cycle again. Therefore a Heavy Duty wash cycle of...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 31, 2011 | Kenmore HE2 Plus Front Load Washer
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
1 beep per second and odd light sequence
there some simple solutions but may not always work but everyone should try. underneath when the water pump engage with the tub. there;s a white plastic clip press it out and turn the water pump. it will come off the tub. before doing this you should have the washer disconnected. have someone or put something under so the washer won;t fell on you while reaching down. sometimes debris gets stucks on the way from the tub to the pump. it insert your fingers inside once the pump is taken out and if you find debris take it out. put back the pump and connect the washer again. this can be a very simple solution it won;t work all the times. but what if it does. :)
Jun 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
My Indesit Washing machine doesn't seem to start?
Most likely water has short-circuited your controls; you need a specialist here.
Apr 09, 2007 | Indesit W 123 Front Load Washer
Whirlpool WFW8400TB Front Load Washer Logo
137 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
