Question about Northstar Garden
The water supply to my pump was disconnected while
The water supply to my pressure washer was disconnected while running. It will not pump water now. Have I burned the pump up and if so can it be rebuilt? It is a northstar pressure washer.
  • 41 Answers
Yes the impeller is probably shot. If you can find the parts it should be easy enough.
Posted on Aug 02, 2009
Water pump runs constantly but no water pressure or water comes out of hose.
Lots of possibilities. Inlet filter might be clogged. I once had a lizard crawl into a water feed line, totally blocked the feed. Check valves might be stuck closed. Discharge hose might be plugged. Pump might be trashed ( if it is a vertical engine it is probably a throw away pump) Nozzle might be plugged.
Disconnect the hose at the discharge and turn on the water supply. It should have a stream of water even without the motor running. That will check the inlet filter, feed pipe and check valves.
Oct 07, 2014 | Garden
Pressure washer runs for 15 minutes then shut itself off. Overheating? I have to let it cool for 30 minutes before it can be used again, may be for 10 minutes before shutting down again. What can b
Not enough water VOLUME and pressure to supply the pump with a steady flow of water. Water is cavatating (adding air to the water) and the piston is heating up and jambing. Try using a larger size hose diameter and a shorter hose to supply the pump.
Apr 22, 2014 | Black & Decker 1700 PSI Electric Pressure...
Portercable Pressure Washer Model PCH2401
when the trigger for the wand is not pulled , there is a pressure relief valve that bypasses the water in the pump and so there is no pressure until the trigger is pulled again.
with the pump getting hot and not being able to pull the motor to restart, it indicates that that pressure relief valve has jammed ( faulty ) and the pump is running at full pressure all the time
That will heat the pump and stop the engine from restarting
That valve is where I would start looking for a problem
Apr 25, 2017 | Porter Cable Garden
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
My pressure washer is a G 2500 oh n i have no pressure coming out, it turns on but no pressure.
Good news, your engine runs
But your pump may be bad
Here's how to test your pump
Check oil as outlined lower down
Disconnect the washer hose and gun
Connect water hose and turn on water and water should pass straight through the pump
Look for clogs in the hose-end where water hose connects to machine
Turn on machine and see if water shoots out pump
If water shoots out of pump, but no water shoots out of gun, then you may have a 'mud-dobber' wasp clog in your washer line or gun
Look for clogs in the end of each water connection.
Now connect washer hose without the gun, tun on the machine, and see if water shoots out of washer hose
Finally, the gun trigger mechanism may be bad
I don't know which gun you have ... but we replaced guns on our machine now-and-then ... google-search power washer guns for a replacement
Check your pump oil
Pump oil is SAE20 or SAE30 non-detergent motor oil
Pump should be no more than 1/2 full of oil
Use plastic hose to drain pump oil
Do not turn machine on its side or turn machine over or engine oil will run into carburetor
Oct 20, 2010 | Karcher 2500 PSI Pressure Washer
Motor running, water supply adequate but when
clean whole water supply and outlet from all debris, clean inlet filter as well. connect water and pressurise washer, pull trigger and wait about 3sec for pump to activate, if pump do not activate adn you have pressure from nozzle as it will be from main, this determines pressure sensor (it is extremelly rare for pump itself) is damaged.
check if you have still warranty,this will qualify as warranty repair, if warranty is expired, pressure sensor need to be replaced.
if you find my advice useful, please do not hesitate to leave your remarks and vote for me, thanx!
Jul 31, 2010 | Karcher 1750 Psi Elec Pressure Washer
KOHLER HYDRO 13 When pressure washer engine is
first sheck the inlet screen where the garden hose attaches,if there is water flow then see if it has a manual pressure regulator, this will be a knurreled knob somewhere on the intake manifold of the pump, ifyou have one, turn it clockwise and see if there is a difference. If still no luck, disconnect the high pressure hose from the pump, start it and see if warer flows at that point, Your gun may be clogged or your hose may be delaminating on the inside and need to be replaced. If all this fails I suggest you bring it to an expert. These pumps can require special tools and expertise to repair internally
Nov 08, 2009 | Karcher 2500 PSI Pressure Washer
What is the best way to winterize a standard large capacity washing machine?
If the product will be exposed to sub-freezing temperatures, turn off the water supply to washer, disconnect fill hoses, drain them and reconnect. Remove the drain hose from the standpipe in the wall and place it into a shallow pan at floor level untill the water floe stops. Unplug unit and you are good to go.
If no sub-freezing temps are expected, turn off water supply. Turn on washer for a warm wash cycle for a few seconds to relieve the pressure in the hoses. Turn off machine and unplug it.
Nov 04, 2009 | Kenmore 22422 Top Load Washer
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
103 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
