Question about Danby DPAC120068 Air Conditioner
Temperature stuck at 81 f... after a friend gave me the unit, was working welll at his appartment
  • 2 more comments
  • erosshilova Aug 02, 2009
    no lights on, compressor look to work ...
    I didnt saw any locked issues in the manual
    temp is at 77.....outside 65 F (start at 3 pm )
    i used extension pipes to go out because the ones with the machine to short.....
    im living on one floor, 5 aprt and i try to keep it at 72 F.....Can i?
    There a small part bottom right that i can remove , with holes dont see it in the manual ??
    Did you ever try to take it to second floor alone in your hands,,,,,,Maybe the thermostat is the problem so what can i do ??
    nope
    Genius:
  • 1,689 Answers
Hi erisshilova,
thank you for using fixya.
with regard to the temp being stuck at 81f, there is a strong possibility that moving the device set it to a preventive lock to keep the system safe. else, the thermostat may have been damaged on the move.
first, you may want to refer to the manual and make sure the device is not locked and set temp as desired.
http://www.danby.ca/cms/uploads/products/en_manual/DPAC120068_EOM.pdf
if this did not help, let me know, we will try to find a way to perform a DIY repair on the unit's thermostat.
regards,
voodoo
Posted on Aug 02, 2009
  • marlon john madrid
    marlon john madrid Aug 02, 2009
    the holes are just vents for the machine.
    btw, do you recall the unit having trauma while being moved? looks like it has a very delicate thermostat and condenser since it is somewhat considered portable.
In sink erator model I-81 not working.
Stick the end of a broom stick down in and try to un-jam the blades by spinning them. sounds like there is something stuck in there.
Jan 05, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How to remove ignition switch from 81 chevy pickup
there a long rod on the steering wheel coming from key ing my is face stright up do i have to take the steering collom appart to straight it out
Sep 08, 2011 | 1991 Chevrolet C/K 3500
I am told that getting a replacement coil for this ac unit would be next to impossible. Where could I find one for this unit.
who ever told you that gave you good advice. IF you find a new coil the cost to insall it will be ... welll .. costly. I am not certain how old the unit is but if it needs a new coil because its been punchered or has corroded . Your mony ahead in the long run to replace it. If its just a small puncture it can be fixed easily .. Hope this helps let me know
Aug 02, 2011 | Goodman PHKJ048-1 Air Conditioner
Paper jam on right side only
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 27, 2010 | Lexmark X5495 Printer
Grandaughter gave me her TI-81. I replaced all
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Sep 09, 2009 | Texas Instruments TI-81 Calculator
Need assembly instructions to a home gym
Hi, I have 2 sets of those assembly instructions. I was just selling them on ebay for 15.00 as they are many pages. If you're interested, you can contact me at in2love@sbcglobal.net, thanks, chris
Jul 01, 2009 | Exercise & Fitness
Having sharp Photo copy, Model-AR121. It is not working. Pls. provide me service center.
Sharp AR-121 code
CC Original not detected E1 00 Lost communication with the Sorter 10 Lost communication with the Sorter 11 ASIC error 12 Image Processing Unit error 13 ROM error 14 NVRAM error 15 Page memory fault 16 SIMM not present or installed incorectly 17 Page rotation error in RAM 80 Electronic sort board error 81 82 84 88 E7 03 Lens position error 04 White level calibration error 05 Black level calibration error 12 CCD calibration error F1 06 Shift sort motor overloaded F5 02 Exposure lamp blown F6 00 Fax board problems 10 80 81 82 84 88 F9 00 Printer board problems 10 80 81 82 84 88 H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded 10 Separation motor overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error U2 04 EPROM error 11 Main counter error 12 EPROM error U3 29 Mirror position error U9 00 Op panel problem 81 82 84 88 U95 Firmware error
Apr 08, 2009 | Sharp Office Equipment & Supplies
TI-81 manual
  1. Right click the link below
  2. Click Save-As
  3. Save to Desktop, or other location on your computer
  4. Enjoy
http://education.ti.com/downloads/guidebooks/graphing/81/81$bookeng.pdf
Nov 07, 2008 | Texas Instruments TI-81 Calculator
My airconditioner is just not cooling the way I feel it should. The thermostat never shows lower than 81 degrees. I have it set down as low as 68 but it only cools to 81
Is this a central unit or a window unit. The central unit does 15*----18 * temperature difference from the air comming in the return air grill to the air going out the supply air grills...9*----to ----14* degree different, and the unit is low on freon,, 15*--18* and the charge of freon is perfect, 19-----22* difference, then the air flow is too low , due to either a dirty filter,, dirty squirell cage blower wheel, and last , but not least, the ac inside coil is plugging up!
Sep 07, 2008 | Heating & Cooling
Samsung d807
yes if you are inexperience them you may not connected all the clips back on or damaged the cable....so my advice is take the mobile to a repair center and have the pros check it out..
Apr 23, 2008 | Samsung SGH-d807 Cellular Phone
Danby DPAC120068 Air Conditioner Logo
180 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
