If your Sharp LC-45D4CU television is not producing sound when you connect an external speaker or sound bar to the audio out jack, there are a few potential causes and steps you can try to fix the issue:
- Check the audio out jack: Make sure the audio out jack is clean and not damaged, and that the connection to the external speaker or sound bar is secure.
- Check the audio settings: Make sure the TV's audio settings are set to output sound through the audio out jack. You can check the settings in the TV's menu or user manual.
- Check the external speaker or sound bar: Make sure the external speaker or sound bar is turned on and set to the correct input. Also, check the speaker or sound bar's connections and make sure they are secure.
- Check the cables: Make sure the cables connecting the TV to the external speaker or sound bar are not damaged and are securely connected.
If these steps do not fix the issue, there may be a problem with the TV's audio out jack or the external speaker or sound bar. In this case, it is recommended to contact Sharp customer support or a TV repair technician for further assistance.
Regenerate response
