Question about Sony Televison & Video
My Sony 32'' Trinitron Model KV32S42 went black and will not turn on. The standby light blinks continuously about every second. What happened? Can it be fixed?
  • bmccrary Aug 02, 2009
    you said I would need to replace the power supply. Where is this located and is this something I can do myself or hire out?
  • 4,234 Answers
This could be a sign of the picture tube starting to fail. If you are comfortable working inside the set where there are potentially dangerous high voltages, try the following:
Remove the back cover and locate the flyback transformer (part with large red wire coming out the top). Do not touch the red wire!! There should be 2 controls on the rear of the transformer. One should be marked screen and the other focus. Turn the screen one slightly clockwise. Plug in the set and try turning it on. If hte picture returns, the picture tube is starting to fail and changing the screen control is only a temporary "fix" that will buy you time to find a replacement set. It may last weeks or months or fail again within a few days.
Please try that and update this with the results.
Thanks,
Dan
Posted on Aug 03, 2009
  • 11,896 Answers
You will have to change the power supply
Posted on Aug 02, 2009
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony trinitron 32" tv just went black and the
Hello
Six blinks of standby light in Sony TVs denotes the absence of horizontal oscillation.
No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
In most cases the Ic is foud defective. anyway check its soldering points for any loose contact, or bad solerings. Check the line drive transformer, a very little transformer soldered directly to the main printed circuit board, very close to the horizontal output transistor. Check its primary winidngs for open. If it gets open no horizontal drive signal will be present at the base of the horizontal output transitor, that also may the cause of horizontal stop.
Nov 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV went OFF
The standby light should be blinking in a repeated pattern. Count the blinks and report that number here. This will indicate the circuit that is defective and will allow us to provide a repair suggestion.
Thanks,
Dan
Apr 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-32xbr400 switch problem
Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it. in yor case you have 5 blinks that´s why the last is short to be possible the count..Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
May 18, 2009 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony WEGA Trinitron SRS BBE 32'
Please reply couple of questions about TV to guess what could be wrong.
1- How many times standby light blinks, there would be interval of 3 seconds in blinks so count pause to pause.
2- Please intimate exact model of TV, written on sticker pasted at back of TV. That will help me to check its schematics.
Hit " add a comment" button to reply.
Thanks.
May 03, 2009 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I GOT A SONY THAT I BOUGHT LAST JUNE OF 2004 NOW I CANNOT POWER IT'S JUST SAY STANDBY
1. Will it turn on at all?
2. How many times does the standby light blink? Is it consistent and continuous?
3. Did the screen do anything strange before this happened (did it turn pink? Any lines across the screen?
Answer those questions and I'll try to help you.
Nov 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Trinitron kv32s42
Can you tell me how many times red standby light blinks?
Feb 11, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
