.CHM files Just bought a new printer and can't open the manual which has loaded OK from CD. Problem is that Windows XP will not allow the opening of the file as it is a .CHM file and the last MS security update has blocked these from being opened as they are regarded as a security risk. Canon are unable/unwilling to offer a printed version of the manual or a solution to my problem.
    Genius:
  • 2,985 Answers
I cannot get rid of pceu virus on a windows xp pro fujitsu desktop because it has disabled safe mode and I do not have the windows xp cd to reinstall windows and the cd/dvd drive does not work .
Download the SP3 installation ISO. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en xp pro sp3 iso http://www.imgburn.com/ Download the iso also download the imageburn or
http://windows-xp-pro-startup-disk.soft32.com/ Bootable disk for XP Professional. The Windows XP start up disk allows computers without a bootable CD-ROM to perform a new installation of the operating system. Hope this helps.
Jan 21, 2013 | Fujitsu Computers & Internet
An internal application error has occurred
Method 1: Reregister Jscript.dll and Vbscript.dll
  • Click Start, and then click Run.
  • In the Open box, type regsvr32 jscript.dll, and then click OK.
  • Click OK.
  • In the Open box, type regsvr32 vbscript.dll, and then click OK.
  • Click OK.
If either of the files do not register as expected, or if you receive an error message, the system file may be missing or damaged. To extract the missing file in Microsoft Windows XP, follow these steps:
  • In the Open box, type msconfig, and then click OK.
  • Click Expand File.
  • In the File to restore box, type the name of the file that you want to restore.
  • In the Restore from box, type the path of the Windows XP .cab file where you want to restore the file, or
    click Browse From to locate the Windows XP .cab file.
    Note The Windows XP .cab files are stored in the I386 folder on the Windows XP CD.
  • In the Save file in box, type the path where you want to extract the new file, or click Browse To to locate the folder that you want.
  • Click Expand.
  • In the System Configuration Utility dialog box, click OK. If you are prompted to restart the computer, click Restart.
Open a dialog box that previously experienced the issue that is described in the "Symptoms" section of this article. If the issue recurs, go to the next method.
Jun 14, 2011 | Microsoft Windows Media Player
How to create bootable cd?
The following items are required:
  • A copy of the original Windows CD/DVD or ISO.
  • A copy of the Boot Files (Downloaded Below).
  • A minimum of 1GB available hard disk space for CD's.
    A minimum of 5GB available hard disk space for DVD's.
Create a folder called OS on your hard drive (C: is used in this example).
In this folder create two sub-folder called BOOT, and ROOT.
Copy the entire Windows 2000/XP/2003 CD (or extract the ISO) into folder ROOT.
1.) Download boot file. (bootfiles-from-tacktech-website.zip ~1.34KB)
2.) Extract the BootSector file (boot.ima) from bootfiles-from-tacktech-website.zip
into the folder C:\OS\BOOT
Start Nero Burning ROM.
Select File > New... from the menu.
1.) Select CD-ROM (Boot).
2.) Select Image file from Source of boot image data.
3.) Check Enable expert settings (for advanced users only!).
4.) Set Kind of emulation: to No Emulation.
5.) Set Load segment of sectors (hex!): to 0000.
6.) Set Number of loaded sectors: to 4.
7.) Set Platform identifier: to Intel x86 compatible.
8.) Press the Browse... button.
Locate the BootSector file (boot.ima) in the folder C:\OS\BOOT.
Click the Open button.
Click on the ISO tab.
- Set File name length to Max. of 31 chars (ISO Level 2).
- Set Format to Mode 1.
- Set Character Set to ISO 9660 (standard ISO CD-ROM).
- Check the Joliet check box.
- Check all Relax ISO Restrictions.
- Check Allow more than 64 characters for Joliet names.
Click on the Label tab.
Remove the check from Also use the ISO 9660 text for Joliet.
Enter the Volume Label into the ISO 9660 and Joliet text boxes.
Click the More fields button.
- View Windows 2000 CD Labels (TTID# 269)
- View Windows XP SP0 CD Labels (TTID#226)
- View Windows XP SP1 CD Labels (TTID#283)
- View Windows XP SP1a CD Labels (TTID#312)
- View Windows XP SP2 CD Labels (TTID#342)
- View Windows XP SP3 CD Labels (TTID#422)
- View Windows 2003 Server RTM CD Labels (TTID#292)
- View Windows 2003 Server SP1 CD Labels (TTID#355)
- View Windows 2003 Server R2 Disc Labels (TTID#387)
Enter in the Volume Label into the System Identifier, Volume Set, Publisher,
Data preparer, Application
text boxes under ISO 9660 and Joliet.
Click the OK button.
Click the Burn tab.
- Check Write.
- Check Finalize CD (No further writing possible!).
- Set Write Method to Disc-at-once. (We have had Track-At-Once work as well.)
- Click the New button.
- Locate the folder C:\OS\ROOT.
- Select everything in the folder and drag it to the ISO compilation panel.
Note: Some files are not show in the following image.
- Click the Write CD Dialog button.
Click the Boot tab.
- Verify the settings. Correct if needed.
- Click the Burn button.
Wait for Disc creation to finish.
Click the Done button.
Process completed. You're done.
Regards
Pcs365.8
Jun 01, 2010 | Microsoft Windows XP Home Edition
I'm not able to find a manual for the Creative Muvo T 200 MP3.
Unfortunately, you won't be able to view the manual on your Mac without installing 3rd-party software.
You'll need to find a CHM viewer for your Mac. I can't guarantee this particular program will open the manual you downloaded from Creative, but there's a good chance it might.
Go here and scroll down to the xCHM for Mac OS folder. Download and install the latest version of the software. From that point, you can try to open it using the xCHM program.
If that doesn't work, you'll have to try to obtain access to a Windows XP computer and use the following instructions.
For viewing the guide to the Muvo T200 on a Windows XP machine, go to this page. Under "Getting Started," click on "Quick Start User Guide."
Click on "Download." There will be an "Agree" button. RIGHT-CLICK on that button, so that you can save the file (it is a file with a .CHM extension) to your computer. (Opening it at this point won't work).
The instructions on the site explain how to open the file. Here they are, for your convenience:
...follow these steps to view its contents successfully:
  • Save the manual on your computer.
  • Right-click the manual and select Properties.
  • Select the General tab, click the Unblock button, and then click OK.
The manual should display correctly when you open the file again.
Once I followed those instructions (going to the properties of the downloaded .CHM file and clicking on Unblock then APPLY), I was able to open and read the file in its entirety (meaning the links/chapters within the help file worked properly.) Try it a second time in case the file doesn't show the correct info the first time (it's what I had to do).
Here's the text from the first paragraph of the "How to use this manual" chapter that is beneath "Creative MuVo T200 User's Guide:"
"This document has been designed to provide you with complete product knowledge. You can resize the document window, print this document, access linked web sites and get information from specially prepared graphics."
Good Luck!
Feb 09, 2010 | Audio Players & Recorders
I cannot open chm help file in my computer it show error massage
Right click on the file. Choose Open With. Find the Microsoft Help program in the list and check the "always open this file with" check box.
Nov 30, 2009 | Dell INSPIRON 6000 CENTRINO...
I can not boot my pc with intel MB845 chipset,error in first
RAM, Processor and Motherboard could cause the same problem. check all these.
some time virus also not allowed to install windows.
Nov 29, 2008 | Intel Desktop Board D845WN Motherboard
XP refuses to restart after installing printer
It’s not uncommon for software to mess up during installation.
Or even have a bad CD. (Please make sure you're windows XP software is up to date, run windows update service).
Since you are able to get into windows, open control panel, open add/remove programs & uninstall the Lexmark printer software. After uninstall restart the PC. Power on the printer before windows loads. See if windows runs with the printer connected & powered on. Less Its driver software. Windows should see the printer & ask for the software. (If so, it may be corrupted software). Go to Lexmark for driver software & download it.
http://search.lexmark.com/printer/US/en/1410000
Try reinstalling using the online driver software for the X3550 printer. If it still stops you're windows, I would suggest replacing the USB cable. If replacing the cable does not help & windows does not load, there could be something wrong with the printer.
If this is a new printer you should contact Lexmark.
http://support.lexmark.com/static/229-1-0-582.html
Lexmark will suggest all of the above. You'll be three steps ahead of support. Lastly, I have come across an issue from time to time installing printers software into Windows XP systems.
(It matters not the printer model). Windows was missing basic printer files needed to operate any given printer. The fix for those systems was a complete fresh install of windows. Its suggested to never use a copied windows CD. It matters.
Good Luck electrics!
If I can help you further, feel free to post.
There is rarely 1 way to fix every thing.
Mike
May 30, 2008 | Lexmark X3550 All-In-One Printer
I Purchased new HP notebook - with vista operating system today. Loaded driver for my Konica Minolta 2530 DL from cd provided with printer. Indicated it was successfull. The printer indicates ready and...
that's a printer settings issue...when you open the print dialogue..go to print preferences, and make sure you are selecting the printer, and NOT print to file
Apr 27, 2008 | HP DeskJet F380 All-In-One Printer
Failure to Communicate
try re installing the drivers for this printer check all cable connections once again. did the printer work well at ur frens place? and wat os did he use??
Aug 29, 2007 | Canon MultiPASS F60 All-In-One InkJet...
147 people viewed this question
k24674
jasbo
jasbo
