Question about Refrigerators
My refrigerator door is hampered by the door hitting the middle upright and it has to be pushed shut
    Top Expert:
  • Refrigerators Master
  • 19,466 Answers
Adjust level or tighten or realign hinge
Posted on Jun 16, 2018
3 Suggested Answers
Number5Gayle
  • 98 Answers
SOURCE: refrigerator side not sealing tightly when shut.
Sounds like you may need a new magnetic seal. It is worth the money to fix it, saving electric and your food items.
Good Luck
Posted on Aug 09, 2009
  • 842 Answers
SOURCE: refrigerator door is hitting the
There are 3 screws to the top hinge above each door, if you have a cover on it there is one addition screw to that. Loosen all 6 screws (do not remove them) this will allow you to adjust the doors the tighten back up when done. This should solve your issue you have.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Posted on Aug 28, 2011
Stop alarm beeping
If you had a model number (on a sticker inside the fridge), there's probably a manual online that tells how to adjust the door.
Dec 28, 2013 | Kenmore Refrigerators
Refrigerator door is hitting the freezer door when closing it (the middle inside rack in the door) is hitting the inside of the refrigerator - unsure of the fix please help
Good Luck
Aug 28, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Chrysler sebring trunk lock wont latch and stay shut and locked
On the Sebring, there is a small switch on the trunk where it latches. Right in the middle, there is a small button you can push, which will allow the trunk door to shut. It just needs reset. Right where it goes down to lock at.
Mar 03, 2011 | Chrysler Sebring Cars & Trucks
I have a maytag upright freezer. It is on the coldest setting. A bowl of water on the bottom shelf freezes overnight. The middle one is freezing, but not entirely. The top one is still water, but cold....
check to make sure door seals are touching the frame all round, could be an air leak,also make sure there is no ice build up around the inside casing. if so fully defrost unit,clean all vents/drain pipe, then turn back on and leave it for 24hrs (freezers work beast when full).....and door shut..how many times have you closed door after them????
Mar 01, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Refrigerator side not sealing tightly when shut.
Good Luck
Aug 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Upright freezer door won't stay shut
the door maybe disaligned. Look at the the door side on to see if it has dropped a little. It may just need adjusting.
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire upright freezer door will not open. Seems to be stuck shut! I do not have a locking mechanism on it.
no majic to it - just held by a partial vacuum inside. push a small rounded stick thro the seal where it touches cabinet to release the vacuum
Aug 09, 2008 | Frigidaire Refrigerators
French doors
There is a drain in the bottom of the box to allow water to run out into the pan under the unit. Sounds like it is plugged up causing air pressure to be able to build when you shut either door.
Jan 27, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
855 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
