Question about Hayward Pool Products Volute, Pump
After bumping, dirt goes back into pool. - Hayward Pool Products Volute, Pump
  • 990 Answers
This is probally a cracked plate in filter of bad fingers. You should take this filter apart and manuely clean it at least once a year and check these at that time.
Posted on Aug 24, 2009
How do I backwash an Apollo VA-52-2 without sending dirty water back into the pool?
make sure filter connected correctly if ok after backwash then rinse if dirt goes into pool bad filter elements or multiport
Jun 03, 2017 | Apollo Pool & Spa
How to replace laars lite 2 LD250 ignitor
turn off power remove white leads from fenwall remember which goes to which on bottom in middle unscrew 5/16" screw remove install new one dont bump or it will break hook wires back up it should work
May 21, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Water gurgling in heater, heat is warm, air is very light coming out of the vents, sometimes air goes cold then comes back warm.. a bump will make it go cold
it's look like the a/c evaporator is block by dirt,oil look at it ..It should be clean as this one
hope it helps
Apr 04, 2014 | 2000 Chevrolet Blazer
Hey i find when im vacuming the dirt i pick up from the bottom of the pool just goes threw the filter and back into the pool, what should i do?
The multi-port valve should be in the WASTE position when vacuuming. Make sure there is enough water in the pool to stay above the skimmer when vacuuming .
Jun 06, 2011 | Hayward SAND FILTER, PRO SERIES
I have the hayward e40ac filter, its about 2 weeks old. When I vacuum or even run pump/filter the pressure goes up on the gauge and i loose suction (hope i described correctly). i have backwashed several...
you have to change d. e. when your pressure starts to climb shortly after you bump the filter.what I found when you first open your pool at the start of the season and have some extra trash and dirt to vacume youwill have to change the d. e. a couple of times.just remember the first charge is 4 scoops and after that you only need 3 scoops since all of the d. e. doesn't come out .I find it helpful to bump the handel several times while you are draining d.e. out of the filter. hope this helps and have a great weekend.
May 29, 2011 | Hayward EC-40 DE Pool Filter with pump
Hi I am having trouble getting consistent power. I have taken it apart and cleaned it thouroughly only to find that the problem still remains. Any suggestions?
Try bumping the filter. You might have D.E. coated with normal accumulation of pool dirt, algae, etc. Your pool filters pump strainer or skimmer baskets could be clogged. Make sure there are no obstructions in your impeller. Finally, check the cover gasket, hand knobs, hose, clamps, etc. Replace or tighten as necessary.
Jul 03, 2010 | Hayward EC-40 DE Pool Filter with pump
We have aEC-65 hayward pool filter with a 1HP motor why does the pump slow down run at higher pressure ?
I believe that this particular model is a DE pool filter. Is that correct? If you are operating with a media other than DE, let me know. Assuming that you ARE using DE:
1. You DE could be coated to the maximum with pool dirt algae, etc. To correc this problem, you need to bump the filter.
2. You could have an overcharge of DE. To remedy,
Bump-Drain-Recharge.
3. Restriction in return line caused by small
eyeball fitting. To correct, change to a larger sized fitting.
4. You could have a partial closed valve on a return line. You will just need to open the valve.
5. Make sure that your pump strainer basket and pool skimmer basket are not clogged.
6. Make sure that your pump impeller valves are not clogged.
May 25, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Why is my filter system losing prime?
It could be one of these issues with your pool filter. Try these solutions. If none of them work, let me know and I will do some more research.
1. D.E. coated with normal accumulation of pool dirt, algae, etc.
Solution: Bump your filter.
2. Pump strainer basket or skimmer basket is clogged.
Solution: Clean
3. Pump impeller vanes clogged.
Solution: Cleaning with a stiff wire brush through the pump strainer opening will usually work. Alternate method would be to disassemble and clean.
4. Air Leak on suction side of pump.
Soultion: Check cover gasket, hand knobs, hose, clamps, etc. Replace or tighten as necessary.
5.
May 17, 2010 | Hayward EC-40 DE Pool Filter with pump
After replacing gasket on filter vacumed pool
I would suspect that there is a fault in the filter, a bnreak in the filter elements, a bad alignment, a colapsed support. something that is letting the dirt get back in to the pool
Feb 11, 2010 | Hayward Pro Series 18" Above Ground Pool...
Hayward Pool Products Volute, Pump Logo
41 people viewed this question
Top Hayward Pool Products Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Hayward Pool Products Garden Expert? Answer questions, earn points and help others
