Question about Palm m105 Handheld
Cannot get my Palm IIIx or Palm 100m to sync using Palm by Access, installed on a Dell desktop running Vista. The problem may be the User Account shows, under User Information, Device (Information not available). Don't see any place where I can enter this information and the Hot Sync for both Palm devices does not connect.
  • 47 Answers
UNfortunately the problem is that vista doesn'y support hotsyncing on older palms.
Posted on Sep 29, 2009
I installed Palm desktop by access 6.2.2 and now my Z22 sync's with outlook which I don't use? How can I stop this and get my Z22 to talk to my palm diary on my pc which I use?
You can always UN-install the software, and re-install the software that you do use. I have some links on software, and user comments on how to re-arrange things to get data to sync. Since I do not SYNC myself, I can only repeat what others are saying, but, chances are you can use the information to help.
My page on the Z22 is at:
kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
I hope the links help you to get up and running again!
good luck
robin dusty graves
Z22 PALM PILOT installed-palm-desktop-access-6-2-2-now-ngl0e1lc0ft3j10pmz4xzklk-4-0.jpg installed-palm-desktop-access-6-2-2-now-ngl0e1lc0ft3j10pmz4xzklk-4-1.jpg
Nov 15, 2009 | Palm Z22 Handheld
How to sync Palm T3 to (Dell) 64 bit laptop via Bluetooth
if you are using 64 Bit operating system you may use following procedure
1) Start > Run > msiexec /unregister
2) In regedit, find the following key:
HKEY_LOCAL_MACHINE\
SOFTWARE\Microsoft\Windows\CurrentVersion\Installer
3) Change MsiExecCA64
From this: C:\WINDOWS\system32\msiexec.exe
To this: C:\WINDOWS\SysWOW64\msiexec.exe
(This assumes a default Windows directory.
Change to reflect your configuration if needed.)
4) Restart the Windows Installer service
(Control Panel > Administrative Tools > Services)
5) Install Palm Desktop!
To go back to the previous settings, just reverse the change made in the registry, and stop/start the service again.
You can also set it back to normal by re-registering the installer:
Start > Run > msiexec /register
Jul 11, 2009 | Palm Z22 Handheld
Can't sync palm tx with new vista based desktop
Sir,
Try to hard reset or check whether the computer is updated OS and also check this link for "How to hard reset"
thanks
good luck
Dec 15, 2008 | Palm TX Handheld
Can't install palmone quick install on vista
Vista and quick install work just fine for me.. Here is the process.. Using latest 4.1 from palm.com
you may loose palm desktop data and the users you have created
shut down hotsync, quick install, and palm desktop
go to start.. Programs... Palm desktop
highlight hotsync manager and left click... Go to properties...
Go to compatibility tab and tick run in windows XP mode
select disable visual themes and at bottom select run as administrator
OK that and go to quick install and palm desktop and do the exact same
restart hotsync manager (you will need to allow the program now)
start palm desktop (you will likely need a new user created) (you will also have to allow)
start quick install and poof it will work like new on your vista PC
I struggled with that one for at least 45 min myself but I can now go to quick install and find my application and upload to my palm and sync with ease!
Hope that helps
Aug 17, 2008 | Computers & Internet
Hot sync treo 650 Zip-Linq cable
i have the same F***** probelm
Mar 27, 2008 | Palm Treo 650 Handheld
Palm M515 and compatibility with Vista Home Premium
I was having a similar problem with my M515.  I had originally installed the Palm Desktop from my CD, which was an older version.  When I totally uninstalled the old version and installed the newer version from the Palm website I was able to do a successful sync.  I'm using Windows Vista Ultimate and Palm Desktop version 4.1.4
Oct 24, 2007 | Palm m515 Handheld
Troubleshooting motorola pc suite in Vista?
There are 2 solutions to your problem.
First Solution:
This error message is due to the user account access control setting in Vista. To prevent this error from displaying go to the control panel, User settings and then disable the User Account Control settings.
Second Solution:
This alternative that doesn't require disabling User Account Control security in Vista: run MPT as administrator (either by right clicking on the MPT desktop icon and choosing "Run as administrator" or checking the "Run this program as an administrator" box in the Privilege Level section of the Compatibility tab of the MPT properties dialog - right click on the MPT desktop icon, choose "properties" then click the Compatibility tab).
Although you'll get an "An unidentified program wants access to your computer" dialog each time you run MPT, the application should work correctly.
This solution would avoid having to weigh the potential security compromise associated with disabling User Account Control.
Oct 10, 2007 | Printronix LaserLine L1524 Printer
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
Palm m105 Handheld Logo
53 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
