Question about EuroTech EWF272 Extra Large Front Load All-in-One Washer / Dryer
Washer drum not rotating - EuroTech EWF272 Extra Large Front Load All-in-One Washer / Dryer
    Scholar:
  • 51 Answers
The reason for the washer drum not to rotate is either the belt or the motor. Check the belt. It may be broken or, it may have slipped of the pulley or drive motor. If the belt is fine, replace the motor.
Thank You for using Fixya.com
Posted on Aug 02, 2009
  • Jeff Rooks Nov 11, 2010
    My EWF272 started doing the same thing. Luckily (or un-luckily) I have 2 of the same unit, so I started swapping parts out. I first swapped the control board (under the top.) The machine still didn't spin. Next I swapped the motors. Still nothing. Then I swapped the control board on the bottom (left side - if looking at it from behind) - and it started spinning.
    The problem now is it sounds like a jackhammer running when it's in spin mode.
    Always one thing or another with these units!
2 Suggested Answers
ned_san_jose
  • 234 Answers
SOURCE: Whirlpool Duet Washer drum won't rotate, can't rotate manually
How are ya? This is kind of technical information that i'm about to give you, so if you're not that technical then you should call a service technician to diagnose. Good luck and thanks for the inquiry :)
F25
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Posted on Aug 09, 2009
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Fisher paykel dryer DEIX2 squeaks when drum rotates
I've had the same issue with my FP washer, thanks for the tips!
Jan 17, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
How to balance a frigidaire washer?
Hello - Are you speaking about being balance without the leveling legs? Is the unit located on complete level ground? Or is the washer tub loose and unable to move? If you are referring to the drum, try rotating it manually when it is turned. If you notice that the drum is not balanced and cannot rotate freely, I would suggest contacting a professional so they can move forward accurately. Washer may possibly have a faulty bearing, unbalance drum or pulley issue.
Dec 06, 2012 | Frigidaire Washing Machines
Front loader washer machine not rotating.
Fisrt, see if you can rotate it by hand, BOTH directions. It should have some resistance. If you can spin it and when you stop pushing it will turn a full turn, your drum belt is too loose. If the belt is good and tight, it will spin less than one half rotation, there is probably something blocking one of the wheels that the drum rides on.
Nov 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
@ speed washer stopped running with a full tub.
if empty drum doesn't rotate with hand then its drum bearing jam.
Nov 02, 2009 | Maytag Washing Machines
Washer won't spin
check the belts not too lose....
cheers
Aug 03, 2017 | Whirlpool LSR8433K Top Load Washer
Grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Oct 04, 2007 | Whirlpool Duet GHW9150P Front Load Washer
EuroTech EWF272 Extra Large Front Load All-in-One Washer / Dryer Logo
156 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
