Question about Yahoo Mail
How do I cancel 'Protocol POP 3? - Yahoo Mail
Mozilla thunderbird asks for i.map configuration. I have lost access to my mail
About IMAP IMAP stands for the Internet Message Access Protocol. It enables a mail client (such as Thunderbird) to access messages stored on a mail server. It is more modern and fully featured than POP (Post Office Protocol), which is the other major protocol for accessing mail messages. Most email providers now support IMAP. To see whether your account uses IMAP or POP, check the Server Settings page in the Account Settings... for more info.
https://support.mozilla.org/en-US/kb/imap-synchronization
Jun 02, 2017 | Mozilla Computers & Internet
How do I install my default mail client for my e mails I have windows 7?
There are many websites that already provide this answer.
Nov 04, 2014 | Google Gmail
How do i cancel nettalk
Log in to your account, click on the "service plans" tab, go to the bottom of the page and click on "remove auto-renew".
Oct 13, 2014 | netTALK DUO II Voice Over Internet...
How do you cancel print jobs in Windows 7?
1. Click Start, Devices and Printers
2. Right-click the printer whose job you want to cancel, and select See what's printing from the context menu.
3. The print queue will pop up. Right-click the runaway print job, and then click Cancel from the context menu.
hope this helps
Apr 14, 2014 | Dell Computers & Internet
Cant recieve emails problem says protocol pop 3 invalid password
open an email click tools accounts mail then on the right select properties you should see your email adress then click on servers you will see
POP3 should have mail. with your provider ie: mail.bigpond.com
and outgoing mail the same mail.bigpond.com
hope this helps
Apr 22, 2012 | Microsoft Outlook Express
Must be reset router tl-mr3420 tplink time to time after connecting DVR Hikvision externally via NO_IP. the router has DDNS enabled and open port-forwaring
1.You will possibly need to configure the router for what is called "port Triggering"
2. from what I read is that there is no IP via the Hikvision external there fore requiring a new IP each time for connectivity.
Instruction set from the manual states:
To add a new rule, follow the steps below.
1. Click the Add New... button, the next screen will pop-up as shown in Figure 4-40.
2. Select a common application from the Common Applications drop-down list, then the
Trigger Port field and the Incoming Ports field will be automatically filled. If the Common
Applications do not have the application you need, enter the Trigger Port and the
Incoming Ports manually.
3. Select the protocol used for Trigger Port from the Trigger Protocol drop-down list, either
TCP, UDP, or All.
4. Select the protocol used for Incoming Ports from the Incoming Protocol drop-down list,
either TCP or UDP, or All.
5. Select Enable in Status field.
6. Click the Save button to save the new rule.
check the "Local management" in the router
you must allow certain devices to obtain an IP via either MAC address or IP address.
Sep 12, 2011 | TP-LINK TL-MR3420 Wireless Router
How to set up outlook express email on acer aspire one notebook
About the setup, it's universal, means that the setup for outlook express is the same regardless of the computer brand. What i can provide you is only a hint on how to get it configured and working.
>First, you need an Internet Service Provider(ISP) because you need to have a Post Office Protocol (POP) and Simple Mail Transfer Protocol (SMTP) server for example, with at&t their pop/smtp are pop.att.net / smtp.att.net and so it needs POP/SMTP port numbers as well the default for those port numbers will be 110 for POP/225 for SMTP.
>NOW, the easiest way to get it configured and running is to call your ISP
>Only if you know those credentials i can walk you through the step by step configuration
>comments suggestions ratings and violent reactions will be greatly appreciated
Sep 22, 2010 | Acer Aspire One PC Notebook
I have yahoo id i wand configure to my outlook express i am getting this error There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server:...
There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server: 'pop.mail.yahoo.com', Protocol: POP3, Server Response: '-ERR [SYS/PERM] pop not allowed for user.', Port: 995, Secure(SSL): Yes, Server Error: 0x800CCC90, Error Number: 0x800CCC92
make sure your password is correct because this error description states that your password is incorrect
Jul 08, 2009 | Microsoft Outlook Express
Message could not be sent. Server rejected sender's email address
the message could not be sent because it rejected as the sender
Jan 15, 2009 | Computers & Internet
Gmail POP3 Error
Set your gmail profile in your gmail account, by allowed pop3 system software download your mail from gmail
Sep 17, 2008 | Google Gmail
Yahoo Mail Logo
42 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
