Question about Garden
How to rewind recoil spring for husqvarna chain saw?
  • 154 Answers
Turn opp way then feed string thru to handle with tension
Posted on Aug 02, 2009
Pull cord on my chain saw will not recoil
Off hand I would say the recoil spring is broken. they can be a bugger to replace. I would remove the cover and take it to a hasqvarna dealer, and have them replace it.
Dec 29, 2012 | Husqvarna Garden
What's the trick to installing a flat coil spring into a chain saw recoiler without having it spring out
If you are having to recoil the spring after its come out. Roll it tightly with your hands then use vise grips on one side pinching it together then you can place it in the retainer/pulley. release
Oct 18, 2012 | Craftsman sears 18" Chain Saw Chain (...
REPLACING STARTER SPRING/HUSQVARNA MODEL141
To rewind the spring is a bit of an art, hook the end of the spring into the stub on the starter, now start to wind each coil into the cover, making sure you keep your thumb on the coils you have wound in so as they do not spring out, otherwise order a new spring which will come pre wound in a keeper to make instalation very easy.
Apr 21, 2012 | Husqvarna Chain Saw 20" Bar
I have a 20" bar chain saw (51 Air Injection)
The part no. of the spring is 501763101 it comes in a plastic keeper so is very easy to fit, check the web for sellers.
Jul 17, 2011 | Husqvarna Chain Saw 20" Bar
Drum clutch on a chain saw
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Oct 29, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How to change pull spring
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly. HTH
Lou
Oct 29, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Installing recoil spring for Poulin P3314
Lou
Oct 17, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan model p3314 recoil spring won't go in correctly
You need to pretension it. Remove the pull handle, rotate the spool about 2 revolutions against the spring, rethread the cord and reinstall the handle.
Lou
Sep 04, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Spring repacement
Hi fwadden
Remove the housing-fan. Remove the screw and detach the pulley- starter and the spring -starter.Put the new spring-starter(it usualy comes with a support).The spring-starter"spires are counterclockwise oriented.Put the puley starter back and the screw.Wrap up the rope clockwise on the pulley-starter until the starter works propperly.Hope this helps you.
best regards savumihai71
Dec 12, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
482 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
