Question about Garmin Nuvi 255 GPS Receiver
Stopped working black screen and will not reset. I updated my maps and entered Favorites. All was good one hour out of the box and I thought I was set to go. While still connected to my Mac I ejected it and disconnected the cable and now it will not turn on.
  • jobobike Aug 02, 2009
    Thank you fixer I found this tip on another site. "Apparently there is some stupid little button on the bottom of the unit that I found. The fun part is it isn't even a button. You have to read the little strip where the sticker is and on there is says reset. Press and hold that button and the unit will turn back on. I hope this helps.
    PS. Remember there isn't an actual button so don't spend a long time like I did searching for an actual button. The button is hidden under the sticker along the bottom."
    I peeled off the sticker and there is a tab beneath that can be pushed in. This is the "reset" button. I did this and all is fine again. I will stick the sticker on my Garmin registration card.
    President:
  • 2,976 Answers
Plug it in, keep the PC turned on ALL NIGHT to get a full charge.
Posted on Aug 02, 2009
Fully charged will not turn on or reset unit is not damaged had been working fine. turned it off and now nothing.GO 2535 WTE
Restoring your Favorites and personal settingsIf you reset factory settings or update your map you can restore your favorites from a device Backup.Your Favorites are located inside your map folder, stored in the file MapSettings.cfg. This file consists of the following:Home addressRecent destinations Favorites Connect your Tom tom to the computer and select the option below that best fits your situation:If you are going to be installing a new map to your TomTom or you plan to perform a factory (hard) reset on your device, choose Backup and restore Favorites from your TomTom. If you have already installed a new map or performed a factory (hard) reset, choose Restore your Favorites from a previous backup.Restoring Favorites from a previous backup can only be done if you have previously performed a backup of your Tom Tom device.
Aug 18, 2011 | Tomtom GPS
My garmin GPS Nuvi 1300 sudenly stopped working enroute to an address. The screen went blank and I could not get it to power up. At the time the unit was connected to my car charger.
Hi, a Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
Take care
Jun 29, 2010 | Garmin GPS
GPS was working fine. Stopped and turned off car....
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 21, 2010 | Garmin nuvi 1300 Car GPS Receiver
1300 nuvi screen comes up loading maps and stops
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
May 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
It will not power on. The name garmin is on the screen with a black background.what could the problem be?
I hope that helps.
May 13, 2010 | Garmin nuvi 1300 Car GPS Receiver
The Garmin Nuvi 1300 was working gret. It was a Chrismas gift. It just stopped working it will not come on at all the screen is blank black. No signal will not turn on at all. Did not drop it or and other...
I hope that helps.
May 11, 2010 | Garmin nuvi 1300 Car GPS Receiver
Reloading map Screen blank
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
May 04, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin Nuvi will not load maps - why
Try the Hard Reset procedure outlined in this tip.
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
Jan 07, 2010 | Garmin nuvi 205W GPS Receiver
How to save favorites when updating map software
Map updates have nothing to do with your favorites. The only time this may be a problem is if you have to do a Master Reset of the unit. Doing a Master Reset will erase all of your favorites, but is not usually necessary when installing map updates.
Jul 01, 2008 | Garmin StreetPilot c340 GPS Receiver
Lost favorites when trying to update
There is no solution, and the manufacturer is not amenable to any news of this.
It used to be possible to remove the mapsettings.cfg file from the TomTom unit's maps before downloading and installing a new map, then to replace the file; however, TomTom changed the coding on the latest maps so that the software no longer recognises the old cfg file. There is a complex workaround where you change your favorites, one by one, into Points of Interest - but it seems pointless having a Favorites item when you have to do this.
Dec 07, 2007 | Tomtom ONE GPS Receiver
Garmin Nuvi 255 GPS Receiver Logo
132 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
