k
kvgautomobiles Posted on Jun 15, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to solve service call -SC556 - Office Equipment & Supplies
Terry
Level 3:
  • Office Equip... Master 11,377 Answers
  • Posted on Jun 15, 2018
Terry
Level 3:
Answers
11377
Questions
Helped
4626385
Points
152765
2answers
Printer Ricoh sp 210 su in error service call sc556
This is most likely a fuser issue. If you have a spare laying around, I would suggest replacing your fuser. If you have a contract with Ricoh, I would suggest placing a service call for them to come out and look at the machine.
How to fix error SC556 on ricoh
It depends from machine to machine. on some you just need to enter into service mode and then copy sp or system sp. On other Ricoh machines you need to execute a reset. first of all turn on the machine, and make sure no print jobs are present, or remove the network print or USB print cable and then turn on the machine. This is just to make sure that no print jobs are present, because this will make you to not be able to enter in service mode. This code SC556 also and other similar SC codes like 551,552,544 and etc. are connected with the Fuser unit. Most of the time is just triggered as security for overheat to stop a melting or fire. So if you reset the machine with procedure you may make damage, but in most cases is harmless. But if you reset the SC556 and then after short time reappear than the machine have real problem and need to be fix, do not reset it more than to to times in a row on a short time period. To enter into service mode press the following keys in the following sequence: press the yellow(clear) - then press 1 0 7 (numbers on the keypad) - then press and hold it pressed the red stop button until service mode appear on the screen. when service mode appear on screen enter into (copy sp) or (system sp) depend from the model of the machine. Then with the keypad press 5-8-1-0-# on the screen should appear Fusing SC reset, press execute and after show complete turn off the machine and wait at least 30 seconds, turn it on again. if its ready the sc is clear. But if the sc repeat the machine have a serious problem with the fusing unit and need to be fixed, if you try to reset the machine with this reset to much in short time you may just add more damage. for more detail post the model of the machine.
How to solve service call sc556 ni ricoh sp212sfnw printer
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
2answers
Do what it says and call service.
2answers
SC556
No such code for that model. But the 500 range you mention is fuser related. Replace the fuser....but parts are no longer made for that model...it was made in 1999.
Sc556
To reset fuser SC codes you need to enter Service Programme Mode and reset SP5-810 to 1, then turn the main switch off and on again. If you need help on entering SP mode etc. then take a look here.
k24674
ADMIN Andrew
ADMIN Andrew
