Question about Garden
Troy bilt riding mower front wheels wont align
I have a troy bilt riding mower and the front wheels wont align when you tighten the tie rods and keep the wheel straight . I dont know what the problem is .
  • dewey wyatt May 11, 2010
    what caused the problem? did you hit something and knock them out of line? check for a bent rod a loose coupling at the steering wheel or worn out bearings on the wheels.there is a bolt which goes thru the steering shaft that can break but then you wouldnt have any steering
  • 376 Answers
SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
Posted on Jun 19, 2009
  • 202 Answers
SOURCE: I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Posted on Jul 31, 2009
  • 62 Answers
SOURCE: Troy-bilt bronco riding lawn mower choke problem
Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
Posted on Sep 07, 2009
wireguy212
  • 1627 Answers
SOURCE: Bought a used Murray wide body 42
There tie rod ends on those rods that can be adjusted,if you see no visible threads than you may need to adjust the other side to match the one tha looks like it is swung out ,maybe it is swung in.
Posted on Nov 10, 2009
dolharoobang
SOURCE: troy bilt pony riding mower will go in reverse but
have a troy-bilt riding mower. place a gear in neutral and park it.
it dies instead idling. want to know why?
Posted on Nov 14, 2009
HOW DO I ALIGN THE FRONT WEELS ON A D130
loosen up tie rod unhook tie rod from spindele turn tie rod in hook tie up to spindle see if straight if not repeat till straight make sure tie rod end is not bad replace if is make sure spindle not bent replace if it is
Sep 04, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
My front wheels are not aligned on my dynamark. How do I align them
disconnect tie rod ends turn out or end to move your wheels out or end when you think there centered measure them with a tape measure to check when close enough tighten the tie rod ends more than likly your going to have to replace parts on it ether bent or worn out
Sep 14, 2013 | Garden
I have a troy bilt 17.5 hp pony riding manual lawnmower and my belt located above the deck keep jumping off track after engaging the blades a couple of times,do i need to tighte my belt,if so how?
Those units are self adjusting. No way to adjust it. It sounds like you have a bad idler pulley or a bad spindle bearings, which would cause the pulleys to be out of alignment.
Sep 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I want to know how to fix the alignment on my 1995 honda accord ex.
Before making wheel alignment adjustment, perform the following checks:
  1. Tires should be equal in size and runout must not be excessive. Tires and wheels should be in balance, and inflated to manufacturer's specifications.
  2. Wheel bearings must be properly adjusted. Steering linkage and suspension must not have excessive looseness. Check for wear in tie rod ends and ball joints.
  3. Steering gear box must not have excessive play. Check and adjust to manufacturer's specifications.
  4. Vehicle must be at curb height with full fuel load and spare tire in vehicle. No extra load should be on vehicle.
  5. Vehicle must be level with floor and with suspension settled. Jounce front and rear of vehicle several times and allow it to settle to normal curb height.
  6. If steering wheel is not centered with front wheels in straight-ahead position, correct by shortening one tie rod adjusting sleeve and lengthening opposite sleeve equal amounts.
  7. Ensure wheel lug nuts are tightened to torque specifications
Ride Height Adjustment
Before adjusting alignment, check riding height. Riding height must be checked with vehicle on level floor and tires properly inflated. Passenger and luggage compartments must be unloaded. Bounce vehicle several times, and allow suspension to settle. Visually inspect vehicle from front to rear and from side to side for signs of abnormal height.
Measure riding height. See figure. Riding height between left and right sides of vehicle should vary less than 1′ (25.4 mm). If riding height is not within specification, check suspension components and repair or replace them as necessary.
Wheel Alignment Procedures
Honda recommends using commercially available computerized 4-wheel alignment equipment. Follow equipment manufacturer instructions to obtain vehicle alignment settings. Use following procedures for necessary adjustments.
Civic Camber Adjustment
Compare camber settings with vehicle manufacturer recommendations. If camber is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck camber.
Civic Caster Adjustment
DO NOT use more than 2 shims. If more than 2 shims are required to adjust caster angle, check for bent or damaged suspension components.
Compare caster settings with vehicle manufacturer recommendations. If caster is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck caster.
Civic Toe-In Adjustment
  1. Secure steering wheel in straight-ahead position. Measure front wheel toe-in. If adjustment is needed, loosen tie rod lock nuts. Turn both tie rods equally in the same direction until front wheels are in straight-ahead position and toe-in reading is correct. Tighten tie rod lock nuts. Reposition tie rod boots if twisted.
  2. Ensure parking brake is released. Check rear wheel toe-in. If adjustment is needed, hold adjusting bolt on rear compensator arm and loosen lock nut. See figure. Adjust rear toe-in by sliding rear control arm until rear toe-in is correct. Install NEW lock nut, and tighten it while holding adjusting bolt.
Wheel Alignment Specifications
  • Camber - Measurement in degrees.
    • Front: 0 (range -1 to 1)
    • Rear: 0.33 (range -1.33 to 0.67)
  • Caster - Measurement in degrees.
    • 1.17 (range 0.17 to 2.17)
  • Toe-In - Measurement in inches (mm).
    • Front: -0 (0)
    • Rear: 0.08 (2.0)
  • Toe-In - Measurement in degrees.
    • Front: 0.00 (range - 0.16 to 0.16)
  • Toe-Out On Turns - Measurement in degrees.
    • Inner: 41.00
    • Outer: 33.50
Torque Specifications Ft. Lbs (N.m)
  • Rear Control Arm Adjusting Bolt: 48 (65)
  • Spindle Nut: 136 (185)
  • Tie Rod Lock Nut: 41 (55)
  • Wheel Lug Nuts: 80 (108)
hope this helps you out.
May 09, 2011 | 1995 Honda Accord
Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Nov 30, 2009 | Mtd Garden
    I have a troy bilt front wheel drive mower, model
    ya the trans is trying to go out and thay look up thay do that all the time
    Nov 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
    Front wheels not aligned
    it sounds like your drag link is bent.look under the front.the rod connecting the two tires should be straight.if not,straighten it and slide a slightly larger piece of galvanized pipe over the rod to stop it from bending again
    Apr 29, 2009 | Troy-Bilt Pony Garden Tiller
    Tie rod inner or outter/how to install
    here is word for word what the manual says:
    REMOVAL:
    1. Loosen the front wheel lug nuts on the side to be dismanteld. Raise the vehicle and support it securely on jack stands. CAUTION: If the vehicle is equipped with Automatic Ride Control (ARC), make sure the air suspention switch is turned to the OFF position before the vehicle is riased to prevent damage to the system components.
    2. Remove the front wheel.
    3. Remove the cotter pin and loosen the nut on the tie-rod end stud. Discard the cotter pin.
    4. Disconnect the tie-rod end fron the steering spindel with a Pitman arm puller.
    5. Loosen the tie-rod end jam nut and back it off several turns.
    6. Apply a paint mark to the theads adjacent to the adjusting sleeve or tie-rod end. Unscrew the tie-rod end from the adjusting sleeve or connecting rod.
    INSTALLATION:
    7. Install the tie-rod end into the adjusting sleeve or connecting rod. Thread the tie-rob end in until the marks made on step 6 align.
    8. Install the tie-rod end to the spindle. Make sure the front wheels and steering wheel are in the stright ahead position. Make sure the tie-rod stud is seated in the taper to prevent it from turing while tightening the nut.
    9. Install the new nut on the stud and tighent it to the proper torque (45-60 ft-lbs). Install a new cotter pin and bend the ends over completely.
    10. Tighten the tie-rod adjusting sleever clap bolts or jam nut to 50-68 ft-lbs. Make sure the tie-rod is posistioned correctly in the same posistion it was in before it was removed.
    11. Install the wheel and lug nuts. Lower the vehicle and tighten the lug nuts.
    12. get the front end aligned.
    Aug 10, 2008 | 2000 Ford Explorer
    Garden Logo
    338 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
