Question about Samsung Televison & Video
When I insert a CD and push play, I get a double image on the screen. There is a vertical line up the center of the screen with the same image on each side.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
For some reason, the chat was cut.  Still, to your concern, check/disable Progressive Scan mode.  Depending on the brand and model number of the DVD player, there would be a P.S. or P.SCAN button on the remote.  In other models, a reset is required.
For additional information, please postback with the brand and model number.
Good luck and thank you for asking FixYa.
Posted on Aug 02, 2009
  • brit_89 Jun 20, 2011
    I have the same problem with mine...it is a C479DVD - Progressive Scan DVD Player with DivX® Playback (Citizen)
    I went through the menu and found something that said PS, but when I switched it nothing happened. Then I looked on the DVD player itself and found a switch on the back that said "Progressive Scan", I moved the switch and it worked!! :D Thanks for the help...saved me making a trip to the store to buy a new one!
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Lcd vertical yellow line and Black Horizontal Line with Double Image Below
Sounds like you pulled the TV apart, good luck. Hope you earthed yourself. You could try a replacement t-con board. if that was the problem. http://electronicshelponline.blogspot.com.au/2012/06/how-to-replace-faulty-tcon-board.html
Apr 08, 2014 | Vizio Televison & Video
Thin red line across screen two inches for the top. Picture above line is good, picture below line has no color and double image.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out.....
May 12, 2011 | Vizio L32 32 in. LCD HDTV
The screen has lines and double vertical images then horizonal black lines form and no image is there - a virus?
there is no virus. the problem is the screen. you need to replace it with new screen or let if fix by a technician. they will replace the vertical and horizontal transistor. or so.
Mar 05, 2010 | Acer AL1715 17" LCD Monitor
Vertical lines and bad ghosting & image doubling
The Nvidea board is going bad - you proved that by using the old one.
Feb 10, 2010 | HP NVIDIA Quadro4 750 XGL (128 MB) AGP...
I have a 2006 RCA model R52WH73. The horazonal lines suddenly went to being concave lines and now you see a double image.
horizontal circuit problem .. vertical double image or horizontal.. check screen voltage and focus setting on board. CAUTION: EXTREME HIGH VOLTAGE. QUALIFIED SERVICE PERSONELL ONLY .. serioius high voltage..
Dec 15, 2009 | RCA Televison & Video
No image in my screen
When you ask for help, give make and model number. In this case, if display is a CRT type (cathode ray tube, not LCD), then a horizontal single line in the center of the screen indicates a lack of vertical deflection. If it is a vertical line in the center of the screen, it is a lack of horizontal deflection. Both problems can be caused by any number of components, all internal, and requires a technican to repair. Lowrance has a fixed fee system for their factory repairs. See their online info for support: http://www.lowrance.com/en/Support/Service-Information/Service-Rates/
Sep 30, 2009 | Lowrance Boating
No image only a dotted line in center of screen that also dissapears after 30 seconds.
the vertical scanning had stopped .requires a vertical ic and caps,dont leave on to long or burn will happen to the screen.
Nov 18, 2007 | Toshiba 32AF43 32" TV
Blurry vertical lines with no focus on screen
go to the sony service center for replacing the ccd image sensor....cause it is already damage l know it is free for replacing that sensor cause of production error of the sensor....
Sep 25, 2007 | Sony DCR-HC18E Mini DV Digital Camcorder
Vertical lines jumping across screen
If the double image is in a differant color, then its your convergence IC's that need replacement. This is not a job for the unexperienced person. If you have no electronic repair experience, please seek out a pro to assist you in this repair. There are two IC's, about 3"X5" that are black in color and have STK with several numbers following them. Good Luck PS please dont forget to rate this thread.
Nov 02, 2006 | Mitsubishi VS-55705 55" Rear Projection...
Televison & Video Logo
96 people viewed this question
Jerry Greenberg
Jerry Greenberg
