Question about Maytag Dishwashers
My Maytag dishwasher goes for long stretches when it won't turn on even though I push the proper buttons. The buttons won't light either. It turns on by itself after a couple of weeks of sitting idle. Some of the lights may blink on the start panel while the dishwasher doesn't work, but only on occasion will it fully operate. I have turned off the power and turned it back on, hoping to reset the computer part of the dishwasher. It didn't work.
  • rschluep Aug 04, 2009
    I appreciate your possible solutions, but it seems odd to me that the dishwasher will all of a sudden start working on its own. The lights will automatically start flashing and when I close the door it runs. It can't be a blown fuse or tripped breaker or to my thinking not a malfunctioned part. The dishwasher ran two days ago but now won't work. What it typically does it start working again in a week or so. Does this help isolate the problem more?
  • 15,935 Answers
The Control Touch Panels like to fail on may brands - especially Maytag. They are sensitive to humidity - and a lot have the vents out the front - right by the control panel.
Please reply using "continue with this expert" with your exact model # so I can directly link you to your replacement part and you can decide if it is worth repairing.
Most control Panels run in the $175 to $250 range depending on age and functions.
Posted on Aug 05, 2009
  • 10,865 Answers
Hello. I can help you isolate the problem. You have already taken the first steps, which is excellent. Here are all of the possible causes:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on Aug 02, 2009
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
I have a maytag dishwasher theres a 3 second button to hold in order for it to start but it won't start it's stuck on 3 second lite
hold the heated dry button for till that light goes out. then try to start. it is a child lock that is on
Oct 08, 2011 | Maytag MDB7100AWB Dishwasher
Maytag dryer mug15pdaww won't light, the ignitor
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 16, 2011 | Maytag Dryers
I have a maytag dishwasher and the light wash light stays on even after a wash cycle. Tried to press normal wash and goes back to light wash. What could be wrong?
Buttons could be shorting out and not makeing proper contact from just being old,How old is you unit?? Alway put age with your question,,on anything! Nobody wants to beleive there unit is old,Humane nature I guess, Always keep manual with purchase date in it handy.If it lasted more than 5 years your very lucky.specially if you use it everyday.
May 15, 2010 | Maytag 24 in. MDBH950AWS Built-in...
My dishwasher won"t wash. Help me, PLEASE???
Try pushing and holding the "Air Dry" button for at least 4 seconds. This should turn the control lock off.
Sep 14, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Maytag Quiet Series 300 only goes to RINSE ONLY
Try unplugging the washer to reboot the computer board. Sometime power surges at night can cause undervoltage on the board and make it do funny things. Rebooting by removing power for 10 min will drain the board and start with a fresh program. This is true for microwaves, dishwashers, dryers, etc.....
May 08, 2009 | Maytag 24 in. MDB5600A Jetclean II...
The heated dry and clean lights flash together
I had this same problem. I read on another blog that the manual recommends that you turn the power off to dishwasher. When you turn the washer back on, the lights still flash but then push the off button. The lights stopped flashing.
Jan 15, 2009 | Maytag 24 in. DWD1500A Built-in Dishwasher
Maytag dishwasher won't start
"unlock" the machine by pressing on '3' and holding for a few seconds. Thats what it says on the back of my dishwasher which is the exact same model.
Oct 05, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Dishwashers Logo
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
