Question about Creative Labs Live! Cam Notebook Pro Webcam
How do you capture video? I hit import - then stop import but it does not show up in the import files box I closed out and saved project. When I opened project I could not see it Could not move to step 2 Help guide did not answer this question.
  • mlm_wealthbu Aug 02, 2009
    I thought I could record with the web cam. Is that not true?
  • 691 Answers
Import usually means get video from recorded source. You need to record or capture video. Difficult to solve without seeing what you are doing, and what software you are using
Posted on Aug 02, 2009
Dazzle DVD recorder software does not save my video properly
You don't say where you are trying to save it to. Try saving it to the default location on you desktop hard drive and then transfer it to your phone.
Sep 15, 2012 | Pinnacle Dazzle DVD Recorder
How do i convert .mov to something compatible with windows movie maker
You can add content to your Windows Movie Maker project either by capturing content directly in Windows Movie Maker or by importing existing digital media files. You can also import existing Windows Media-based content as well as other common file formats. You can import files with the following file name extensions into Windows Movie Maker to use in your project:
  • Video files: .asf, .avi, .m1v, .mp2, .mp2v, .mpe, .mpeg, .mpg, .mpv2, .wm, and .wmv
Dec 14, 2010 | Arboretum HyperEngine-AV 1.4
Cannot save video from vcr
Save should be continuous and automatic when 'Record's pressed. The file is ended and closed when 'Stop' is pressed. The configuration setup tells where the file is to be stored; if no setup was made, it would most likely be in 'my documents' folder. The files are .mpeg types.
Feb 10, 2010 | Diamond Multimedia ( VC500) Video Capture
How do you capture video? Live Cam notebook pro
go to computer then click your camera then click record to record video
Aug 02, 2009 | Creative Labs Live! Cam Notebook Pro...
How do I transfer the mini DVD to Movie Maker
With your Recorded DVD-R Disc "Finalized", and in the DVD player on your computer, you should be able to browse to your videos with Movie Maker.
In MovieMaker, on the left side where it lists:
Movie Tasks
1. Capture Video
Capture from Video device
Import video . . .
You want to "Import Video", by clicking that and browsing to the DVD-R to find what could be MPG files, or VOB files. They're both MP2 DVD format video and audio files.
Tip: Right Clicking in the Import Video Dialogue Box where the files are listed and selecting View / Thumbnails, will present a view of the scenes in each video.
Jun 11, 2009 | Canon DC100 DVD Camcorder
I need drivers for JVC GR-Dv500 camera
GR-DV500 is a miniDV vcam w/c must be FIREWIRE**-connected to a pc to upload video thru video capture or video editing* application while vcam is on playback. Before cable** purchase, note: Firewire port of vcam is 4pin...check the firewire port of PC whether 4 or 6 pin. http://en.wikipedia.org/wiki/Firewire
Normally, the drivers are bundled with your computer OS, such that when the vcam is connected, the vcam is recognized by the video editing programme.
For starters, free Windows Movie Maker* (XP-wmm2 & Vista-wmm6) provides simple & easy way to learn the ropes < click help for details>. Upgrade to other video editing app http://video-editing-software-review.top... accdg. to need & skill level
Video Editing Process
>>> open wmm- start/all programs/wmm->TASK pane
..Step 1. Capture/Import video files (+pics, music) to be edited
..Step 2. Edit- drag/drop files->timeline & enhance w/effects, transition, music & titles
..Step 3. Finish (render)- save Movie file, also save Project* file
..Step 4. Share-burn to CD (to DvD thru a DvD authoring app)
Jul 11, 2008 | Cameras
Memory Problems
The clip can be recovered if you open the temporary directory where Camtasia stores the raw captures in AVI format. The path to the temporary directory can be found by opening the Camtasia Recorder > Tools > Options > Program > Temporary file folder (I'm using v.5 so it may be a little different in other versions).
I've found that there's a certain workflow that seems to work best and you can avoid accidentally erasing your temporary files and having to start your capture session over from the beginning...
  1. Stop Camtasia Recorder - Pressing the Stop button on the Recorder likely won't work, so open the Task Manager (CTRL+ALT+DELETE) and select "CamRecorder.exe" from the Processes tab and click "End Process". Don't open Camtasia Studio right away after doing this step - You'll likely be prompted to recover the recording and in my experience Camtasia hasn't done a very good job at being able to do this successfully and you may end up losing your temp files.
  2. Recover your raw capture files - Navigate to the path where Camtasia stores its Temp files (look above for instructions). Typically, there will be a folder titled "CamCapture{random string of numbers/letters}" - look for a folder with a date modified attribute of the date/time you were working on your project. In that folder, there will likely be several audio and video files as well as an XML data file. The video files will all be 1GB apiece as Camtasia splits the capture into chunks and then pieces them back together to create one continuous file. Cut and paste the files from this folder into a new location outside of the Temp directory. The most important one is the FileWriter{random string}.avi as this is the pieced together file - It will have the largest file size.
  3. Add your media files to the clip bin/timeline - Start a new Camtasia project and import the FileWriter{xxx}.avi clip into the Clip Bin and drag it onto the timeline. Now all of your video/audio should be recovered and available for you to edit. If you have particularly long clips, you may want to check how the audio syncs with the the video towards the end of the clip. If it's messed up at all, you may want to try adding the smaller, chunked recording segments sequentially onto the timeline to see if that helps. If the FileWrite{xxx}.avi clip is good though, you can delete all of the other smaller audio and video clips associated with the capture from your pc to save space - just keep the FileWriter{xxx}.avi clip - the XML can be deleted too.
Good luck - We've had the same trouble here and we use Camtasia almost everyday. In my experience, this seems to happen more frequently when we capture larger dimensions - especially if the capture contains full motion video (as opposed to just screen captures of a product demo or something) and we always seem to have trouble when capturing things that play back FLV or SWF clips at a higher bitrate. This issue is also described in TechSmith's Camtasia knowledge base.
Apr 22, 2008 | TechSmith CAMTASIA STU V1.0 5-9U for PC
Cannot load *.dwz files into Ulead DVD MovieFactory 6
Can't start any new or existing projects at all. Nothing happen
Jan 26, 2008 | Ulead DVD MovieFactory for PC
Can my camcorder work with imovie and if so how do i get my computer to get download my video?
Open iMovie and set it to capture DV. (Click the camera shaped icon opposed to the siscor scissor shape) When you see a blue screen that says (camera connected) and the image pops on screen of image from tape on camcorder set in play mode, you hit the import button and it begins to capture digital movie using DV compression of whatever you have on tape. You should be able to control your camcorder with the video controllers underneath the project window to make selections for the in and outpunts on the tape you wish to capture. Then switch to edit mode by clicking on the scissor button and import the movies you just captured or use them from the clips menu, etc. renedr movie back to tape, if you wish by clicking back and forth from edit mode (scissors) and capture mode (camera silo) and render to and from tape.
Jan 21, 2007 | Canon ZR700 Mini DV Digital Camcorder
Creative Labs Live! Cam Notebook Pro Webcam Logo
51 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
