Question about ASUS Pundit-PH3 (PUNDITPH3) Barebone
USB port does not recognise USB hard disk - ASUS Pundit-PH3 (PUNDITPH3) Barebone
  • navin984 Aug 04, 2009
    Thanks Roety,
    The USB drives (I have tried 2 of them) are detected by other systems including my laptop and 2 other desktops. The one difference between the desktops that can detect the USB drive and the one that cannot is that the desktop that cannot is using XP SP2 while the others are using various (Business/Ultimate) versions of Vista. But I dont see why this (Vista vs XP) should be a problem.
    I already tried using the disk management utility you linked. Thanks anyway.
    One option I intend to try is to open the case and check the jumpers etc..
    The light on the USB drives comes on but I can tell that the USB hard disk is not spinning as there is no noise or vibration usually associated with a working USB hard drive.
  • 585 Answers
Hi, you probably need to partition and format the drive, this can be done by removing it from the USB case and connecting it directly to the IDE or Sata connector, but first try using the disc managment system if running windows XP its located in the control panel within the administrative tools button, here is a helpful link that goes into detail about how to do this. link if not using XP google disc managment for your OS and partition and format the drive so windows can detect it.
Thanks
Eric
Posted on Aug 03, 2009
Not recognised windows vista
You have to go to control panel, adminstrative tools, storage and initialize the drive. However the way it sounds, the drive might have an issue, could be the cable or the usb port
Sep 25, 2012 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomage macmini 1TB not recognised in disk utilities
Check cable. Try different cable. Try different ports you connect the Iomega with the computer with en on the Iomega itself.
Dec 17, 2011 | Iomega MiniMax Desktop - Hard drive - 500...
Computer not recognising hard drive. I have even looked in disk management and it's not recognised there either. The hard drive is lighting up when connected so it is working.
HI sineadkirk1
There are several reasons why your hard disk can not be recognised by the computer
1> usb cable problem
2> usb port problem
3> the problem on a computer virus or hard disk
4> computer problem
5> hard disk problem
do the test one by one to ensure that the root cause
thanks&regards
Jan 09, 2011 | Western Digital Elements powered by WD 320...
Have iMac ejected hard drive so I could remove now computer won't recognise the hard drive
First thing I would do if the drive is connected via a usb hub connect it directly to the imac, then if that does not work try one of the other usb ports. If that does not work connect it to a usb port you know works and then go into the applications folder and then into the utilities forlder and open up disk utility. Once opened your hard drive should appear in the left hand box click on your external hard drive then go to the first aid panel and run verify disk and if any problems appear run repair disk. Hope this helps.
Nov 12, 2010 | Western Digital Elements powered by WD 320...
I am not recognising kigston data traveller
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
NOTE Formating the USB flash drive will delete your data.
May 11, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Apollo 320gb external hdd is not recognised by PC . USB is enabled and recognises other devices.
If the drive came with a disk and they usually do I would recommend you install the disk first and after the installation has been carried out you then try to connect your hard drive via your usb port. Good luck. If this doesn't work then there may be incompatibility issues. What version of windows are you using? Andrew
Jan 17, 2010 | HP Computers & Internet
I have a maxtor 250GB black usb 2.0 hard drive that is no longer recognised by my PC. The usb port works OK with other USB appliances. Its not a high speed 2.0 port but thats not been a problem in the...
Try connecting this drive to another PC/laptop. If the hard disk does not get recognised, you may have to seek help from Maxtor / authorised service personnel to diagonse the issue with the hard drive. Given that there is circuitry in between the actual physical disk and its USB port connector, chances are that the data on the hard disk would be safe and the intermediate circuitry may have suffered a brown-out. Good luck!
Aug 14, 2008 | Computers & Internet
Usb not recognized
if you use it on win 95 or win 98 or vista you need specfic drivers for you usb disk
if you get this on win xp please change the usp ports and use another port to insert the disk one of the ports has to recognise.
if the problem persists the usb port controllor on motherboards needs to be checked for faults or uninstalled drivers ,
if nothing works try a pci to usb internal card and dont forget to loaad drivers . this card has 3 to 6 ports for usb
Jun 10, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
External hard disk and pcmcia cardbus
Try reinstalling the drivers for the PCMCIA card and get drivers for the external hard drive..if that doesn't work then get this here. Don't buy dell they have bad quality products.
May 20, 2008 | Dell 4-Port USB2.0 PCMCIA CardBus Card...
ASUS Pundit-PH3 (PUNDITPH3) Barebone Logo
150 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
