Question about Cameras
RE: Nikon Coolpix S710 There are vertical lines running down the left half of the monitor screen. What should I do? Jim
  • 1 more comment
  • jimurozu Aug 02, 2009
    The following procedure did not work: (1) Turned off camera. (2) Removed battery and memory stick. (3) Pushed down on power button for one minute. Tried this twice with no result. Monitor still has vertical lines on left side.
    Jim
  • jimurozu Aug 03, 2009
    There is no firmware available for this version of the camera. I've tried everything else suggested by the first expert with no effect. Any other ideas?
    Thanks for the help of both experts who helped me eliminate simple solutions. I will send the camera to an authorized dealer. I think it is still under warranty. I'm happy to have found your service since I'm a mechanical moron. I'll keep you in mind for future reference.
    President:
  • 2,185 Answers
Hello Jim,
It could be that the screen was damaged. Was it accidentally dropped?To avoid further damage to the lcd screen, the best thing to do would be to bring this to an authorized service center.
Posted on Aug 03, 2009
  • 453 Answers
Turn off camera Try to remove the battery and the memory card.
Press the power button for about 1 minute.
Posted on Aug 02, 2009
  • Sai Kiran Camsarapalli Aug 02, 2009
    is reset the camera. This is a fairly easy procedure which involves either going into your setup menu and choosing "reset" (or intialize), holding down the menu key for 5 seconds, or, removing the batteries for a few minutes. It may be that the firmware loading got corrupted and the camera just needs to be "rebooted," which is something that turning it on/off won't accomplish. But after which, you should have the camera reset to factory default settings.
    look for firmware updates. Download and install them.
    Even if this does not help then Im afraid that the display has gone bad and that we'll have to contact the manufacturer for a replacement if your camera is under warranty.
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
Windows XP will not recognize Cooxpix S710
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Nikon Transfer or Picasa.
Mar 11, 2012 | Nikon COOLPIX S710 Digital Camera
Service manual NIKON Coolpix S710
Hello if you are looking for the service manual for nikon s710 you can download it cheap from the below link::
http://goo.gl/HDFe3
Thanks
Jul 18, 2011 | Nikon Coolpix S710 S570 S560 S550 S640...
My screen only shows half of the computer and there are different colors of lines on the bottom half. i have tried rebooting my pc but it does not help at all its been like this ever since i left it open...
Sounds like the screen has gone bad.... but could be the graphics card. Try an external monitor. If the external monitor is OK, then the screen is bad. If the external monitor also bad, then the on-board graphics card is bad.
Good luck, Jim
Jim
Preston Computer Services
www.prestoncomputerservice.com
May 31, 2011 | Toshiba Satellite L455D-S5976 Notebook
My Nikon coolpix S710 has suddenly come up with 'Memory card is write protected and wont take pictures now. Does anyone know how to fix it?
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 18, 2010 | Nikon COOLPIX S710 Digital Camera
My new nikon Coolpix s710 cannot hold in memory any of the date settings. Each time i switch it on i have to put the date in.
according to Nikon the inside battery is finished and has to be changed because memory is not working. Bring in the camera for repair.
Jan 12, 2010 | Nikon COOLPIX S710 Digital Camera
I need a master reset, hard reset, firmware reset for my Nikon S710. I try with "erase all" but configuration is not equal to the first time use my camera. I need reset my camera. Thanks.
Two methods...scroll to "reset" in the setup menu and follow the on-screen instructions. -or- Remove the card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on.
Sep 24, 2009 | Nikon COOLPIX S710 Digital Camera
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Vertical lines on left half of screen
The problem is the driver tabs that go from the panel controller board to the panel itself.
This is normally a fatal failure since having it repaired is extremely expensive.
Mar 17, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
