Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
I have a husqvarna 340 chainsaw and it will not idle I need to adjust the carberator screws but I do not know how
  • 41 Answers
Turn the screw labled T in a little. This will raise the idle setting. Heres a link to the manual. Look on page 29 of the .pdf
http://www.northerntool.com/downloads/manuals/195946.pdf
Posted on Aug 02, 2009
    Brigadier General:
  • 4,090 Answers
Then before you completly mess up the fuel mixture by fiddling it might be better not to toucjh it and pass it on to your local lawnmower chainsaw doctor
Saw wont rev up or idle
First thing, try new gas.
If that doesn't do it, you need to adjust the low and high speed circuits on the carb. A good starting point is 1.5 turns out from fully seated. On that saw I'm not positive if you will have access to the adjustment screws unless you pull off the plastic caps that may be covering them.
Feb 01, 2014 | Stihl Garden
Need to know how to adjust the carburator on 240 E Series Husqvarna chainsaw
There is a special tool required to turn the jet screws pt no. 530035560 the screws are marked L and H you need to turn the L screw only this will adjust the mixture at idle, anto clockwise will increase the mixture, the third screw on the carb is to increase the idle speed once the mixture is correct, this can be adjusted with a cross cut screw driver.
Jan 16, 2013 | Garden
How to adjust carberator
Some Husqvarna carbs require a special screwdriver to adjust them, some just use a mall flat head tuning screwriver.
Screw both H and L screws in. Then turn them out anticlockwise the following amounts to return them to standard.
H 3/4of a turn L1 full turn (Chainsaws)
Some equipment like blowers and strimmers are:-
H 2 1/4 turns out L 2 1/4 turns out
Nov 03, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 340 will not idle
To set the H and L adjustments, screw them in until they lightly seat. Then back both out 1 1/2 turns. This will get you in the ballpark. They will still need to be fine tuned for proper settings.
Apr 03, 2017 | Husqvarna Garden
Reference the Husqvarna 350 chainsaw. Why does the chain continue to turn at idle? I just installed a new clutch. Adjusting the idle down causes the saw to shut off upon trying to accelerate.
Sounds like the clutch is still grabing. Easy solution is to apply the chain brake at idle to stop the chain turning. Try adjusting the L screw for a smoother idle.
Aug 05, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 385
Sounds like dirty carberator or carb needs adjustment. How is the spark plug?
Jun 22, 2009 | Husqvarna Chain Saw 20" Bar
Can't set carb. on Husqvarna chainsaw.
Most chainsaws and small engines are 1.5 turns out.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Jun 20, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
Husqvarna 345 wont idle, let off the throttle and it dies promptly
it sounds like you need to adjust your idle screw. you should be able to turn it clockwise 1/2 to 1 full turn to make it idle correctly. let me know if you need any more help with this
Mar 05, 2009 | Husqvarna Garden
Husqvarna 51 chainsaw will barely run, magnito and carberator ok
Probably need to re-adjust the carburetor jets. They are very small screws in the base of the carburetor. They will be labeled with an "H" and an "L" . Set the low speed first by turning it in slowly until the rpm drops slightly then start turning it outward untill the engine idles smoothly. At that point you can also adjust idle speed. Then you need to be careful here but you need to hold the throttle wide open at the same time adjusting the high speed jet. Turn it in until the rpm drops then slowly turn it out. The rpm will keep increasing. Once you get to a point where it is max'ed out then screw the jet back in one half a turn. Changes in altitude like using your chainsaw in town versus going to the mountains for firewood can sometimes make it necessary to adjust the fuel/air ratio.
Feb 18, 2009 | Husqvarna Husky 165
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
1,285 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
