Question about Kenmore Sewing Machines
My sewing machine is getting jammed up after 1 stich it says overload on the screen, what should i do?
  • 46 Answers
Rethread the machine. If you are threading it correctly the bobbin case may have gotten out of place and is causing it to jam every time. Many times the thread comes out of the take up lever (the thing that goes up and down) and you dont even realize it. Rethread first and be very deliberate to get it in the top tension correctly.
Posted on Aug 04, 2009
Jams up after a couple stiches
It's jamming up underneath your bobbin is in backwards turn it over.
Aug 14, 2016 | Sewing Machines
How to change stich to long stich for gathering?
http://www.singerco.com/uploads/download/3e3e5558857ed68836712ac8545abb48178772a5.pdf is the manual for your machine; look at p. 27. You want stitch 00, and then increase the stitch length with the up/down buttons on the control panel.
p. 24 of the pdf covers adjusting the top tension of the machine; you'll have an easier time of gathering if you reduce the top tension about 1-2 number setting.
May 29, 2014 | Singer 5400 Sew Mate 60-Stitch Sewing...
Kenmore will only stich three times then jams all link gone just had serviced 5mths ago
try changing needles, i had the same problem and i put new needles in and it works great now.
Dec 17, 2012 | Sewing Machines
My sewing machine will not stich. i have tryed everything i can find on this problem but nothings working
Make sure nothing has either gotten stuck/caught/jammed somewhere inside it. Insure that the thread stays attached to the needle. Or the material you are trying to sew/stitch may be too thick.
Nov 17, 2012 | Singer Sewing Machines
My stiches keep missing a stich
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
if these suggestions don't help the the machine could be out of
time & the machine would need to be taken to a sewing machine
shop to be checked
Aug 06, 2012 | Husqvarna Huskystar 215 Sewing Machine
When i sew on my LS-1 the stiches are not catching sometimes they do for afew stiches but then get tangeled up at then end of the needle and starts to break
I would change the needle, in case there a burr or it's bent
clean under the needle plate & in the bobbin area for lint or loose threads
Aug 09, 2011 | Sailrite Ultrafeed LS-1 Deluxe Mechanical...
When I am sewing it will sew about 3 stiches and then jam.. It does it if I change weight of material or it will s kip stiches.
Skipped stitches is usually indication that needle is blunt or burred.
Or if you are using a sharp needle on knit fabrics it may also skip a little.
Not sure what you mean by "change weight of material" - do you mean you are sewing applique and going from one fabric weight onto another? or different sewing projects?
It is a good idea to change your needle for each new project (4-6 hours sewing time max) and choose the right type of needle and size for your project.
However, the jamming part sounds more like thread tension issues, especially if the jamming is happening underneath from the bobbin. If stitching is loose underneath, then top tension is the problem and visa versa.
Recheck your threading path, top and bottom tensions and that you have good quality thread. Change the needle, rewind a fresh bobbin, thread up and try again.
There is really good info on www.sewing.about.com or I refer to my Singer Sewing Machine textbook at lot too. Good luck.
Mar 30, 2011 | White Sewing Sewing Machines
I have a Janome 6260. My machine sewed great, but this time when I went to use it the knob on the side of the machine that makes the needle go up and down suddenly got really hard to turn and then when...
I've had the Lo come on my screen of my sewing machine also, but normally when I turned it off it corrected the jam up.
Lo- A button is pressed when the machine halts due to a overload
wait 15 seconds to recover
if thread jamming causes the overload, remove the tangled thread
check the bobbin area for lint & loose threads
also check to see if the bobbin is warped
check you needle to see if it's bent-roll on a flat surface to see if it rolls correctly
if it's blunt it makes a popping sound when going thru fabric
let me know if these suggestions help
Sep 23, 2010 | Janome 6260QC Computerized Sewing Machine
In need to know how to adjust my stiching and needle adjustment/ the bobing is jamming(not stiching)
Stitch length is adjusted by holding down the small button in the bed and turning the wheel to the desired number of stitches. The numbers are either on the wheel, next to the belt pulley, or under a small cover on top of the machine. Hold the button and turn the wheel either toward or away from you to get the stitches you want.
Bobbin jamming is either because of incorrect top tension or incorrect threading. Go to www.consew.com and get a parts and operation manual for free for a 224. It 's the same as the 226.
Mar 10, 2009 | Consew 226R-1
Getting jam all the thread and needle do not mooving
make sure your needle is not dul you may need to adjust your tension as well.
Oct 21, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
55 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
