Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
Compressor not coming on.problem started last week with both sides freezing at lowest setting,now not cooling at all
  • 998 Answers
Check compressor relay
Posted on Aug 03, 2009
Iceream is not freezing
The temperature is not set to high cooling.First check the temperature setting.But if temperature is set right and still the ice cream is not cooling then .Problem relates to weak compressor. ------------- The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that ice cream is not freezing, so that means freezer is not freezing to its required temperature.------- This indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
Even at lowest setting refrigerator side freezes up
Possible failure of the thermostat or the sensor to the thermostat that is not working to control the cooling temperature and hence making the compressor work.
Try and set the thermostat to lowest just a little before it cuts off , if this wont work then the thermostat is faulty. Check the wires of the sensor to the cooling coils.
Mar 13, 2011 | Dometic NDR 1292 Refrigerator
The freeze part cooling failed and then the refrigerator part failed subsequently. Their was a noise coming from whirlpool for a week before it failed
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 31, 2010 | Whirlpool S20DRSS33 Side by Side...
Jenn Aire refrigerator keeps freezing food.
Your thermostat is faulty, pure and simple.
If the thermostat fails to do it's job, your compressor continues to run thus freezing your produce.
Feb 02, 2009 | Jenn-Air JCB2280HES Side by Side...
FRIDGE NOT COOLING
sounds like the starting device for the compressor clicking on/off not always starting, hopefully under 5 years old cause sounds like a bad compressor(full 5 yr warr on on that)
Mar 14, 2008 | Frigidaire FRS26R4C Side by Side...
Whirlpool conquest model side-by-side
You need to replace the compressor start relay/overload. It's on the left side of the compressor. You should be able to remove it from the compressor by hand but you may have to use a flat head screwdriver to pop it loose. When you get it off you can shake it and if it rattles inside it's definitely bad. I bought one for my fridge online for $48. Hope this helps.
Nov 04, 2007 | Refrigerators
FRS26KR4CB1 side by side refrigerator
It sounds as if you have a defective compressor start relay.  It is located on the side of the compressor, usually contained within a black plastic housing (box).  If ordered, it will most likely come with an overload proctector.  Change both parts.
Oct 13, 2007 | Whirlpool ED0GTQXMQ Side by Side...
Kenmore 596.75509400 bottom freezer
JH, did you notice if the freezer back panel was full of frost first time it started thawing? If so you may have a defrost problem. I've had 4 of these control boards (jazz boards) fail on this model in the last week. Behind the front grill, there should be a tech sheet that will show you how to run the componet tests at the control board. Part number for the board is 12002339. This board controls compressor, defrost, damper and fans. Catriver.
Aug 04, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Hot point side by side
Could be stuck in "defrost" mode. Happens a lot. See if you can hear if the compressor is running or the compressor cooling fan is running (in back underneath the unit). Worse case is the refrigerant leaked out and you have a sealed system problem.
Sep 28, 2006 | Hotpoint FFU00 Side by Side Refrigerator
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
53 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
