Question about Fossil CH2473 Watch for Men
Im looking for a user manual for a fossil watch my wife just bought me model number CH2473 can you help?
5 Suggested Answers
SOURCE: Instruction Manual for Fossil Watch
go to fossil .com and click on customer service that is where all manuals are hope this helps
Posted on May 14, 2008
SOURCE: User Manual - Fossil CH2332 Wrist Watch
go to fossil.com click on customer support that is where the manuals are hope this helps
SOURCE: Set time on Fossil DQ1138 Watch
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
Posted on Apr 04, 2009
  • 2501 Answers
SOURCE: Looking for Fossil Twist ME1020 owner's manual
As a last resort you could contact Fossil and ask them to send you one!
Posted on Apr 24, 2010
I bought my wife a Fossil watch with the Auburn University National Football Championship face. I have no idea which Fossil model it is. It arrived today & is not running. Question--What must I do to...
Make sure of course that the stem is pushed all the way in to start the watch. If it is all the way in then your battery must be dead. You can look around the edge of the back for a lifting area and use a pocketknife to pry the back off, the problem is with new watches you may need a jewelers watch press to get back back on. Also be aware some watches have screw off backs and some have screws those should go to your local jeweler...actually because its a new watch i would return it or at least take it to a watch repairman or a jeweler! Hope this helps!
Sep 15, 2011 | Fossil Watches
Hi! I would just like to ask if you have fossil watch with this product code ''ES2453'' & ''ES2354''. I' eve bought the said two watches I hardly find the said...
If you type ES2453 in google you should be able to find advertisements for this watch, even though it is not on their web site.
I suspect that it is a discontinued model, as all the models on their web site have larger numbers.
Jun 16, 2011 | Watches
What type of battery does the Fossil Ch2473 use? I called Fossil and they could not help me, instead they insisted I pay them $15 to replace the battery and wait 2-4 weeks for shipping. However, I...
The vast majority of Fossil analog wristwatches take either a #377 or #379 watch battery. The #379, being slightly smaller, is somewhat more commonly found in women's watches than in men's watches, but I have seen both types used in men's and women's watches alike. However, the Fossil CH2473 includes chronograph functions, which means that you can have multiple motors inside the watch running simultaneously. As a result, it's possible that this watch will require a different / bigger bigger. However, if it's not one of these batteries, or even if it takes a 3-volt lithium battery instead of a 1.5 volt watch battery, it will still be something pretty mundane.
In general, common batteries like the type I expect you'll find inside your watch are commonly found at many drug stores, jewelry store counters at places like Walmart and Target, and even at some dollar stores. Be aware that cheap dollar store batteries are usually alkaline, not silver oxide, versions of the same size battery. Alkaline batteries may work perfectly well in many watches, but they have a somewhat different energy performance curve over time, and, in general, they won't last quite as long as a comparable silver oxide battery. In addition, for reasons I've never been able to figure out, some of the Fossil watches that I've serviced would not function with an alkaline battery--but would work fine when I put in a silver oxide battery of the same size and voltage. I have not been able to see a pattern to predict when this will and will not occur. Lithium batteries, whether "brand name" or generic, should have the same performance curve.
If you do open up your watch to change the battery and don't recognize the battery type/code on your battery, don't give up. Watch batteries have different numbering schemes, depending on the manufacturer. Here's a link to a cross-reference chart that will help you "translate" one code into another. I would suggest starting by looking at the #377 line to see if one of those cross-reference codes matches what you have. However, you may need to look around the chart to get an exact match:
http://www.watchbatteries.com/custom.aspx,,id,,75
As a final thought, the backs of some Fossil watches are very snugly fitted to their cases. You can generally get them off without too much of a problem, but there's a good chance you may need a jeweler's press to get them to snap back on properly. I've noticed this most with round watch backs; I generally haven't needed a press to close oblong or tonneau-shaped Fossil watches (or some round watches, too). A jeweler's press spreads the pressure evenly around the edges of the watch back and watch case, preventing damaging pressure on the watch crystal, watch movement, and watch back. Clamping the watch in a regular vise to try to press on the back runs a high risk of damaging your watch, and I do not recommend trying that, no matter how frustrated you get. It's much safer (and cheaper, overall) to tip someone with a vise a couple of dollars to close up your watch for you.
May 15, 2011 | Fossil CH2473 Watch for Men
Bought a fossil FS-4283 came with no users manual!!!
Hi. Follow the link to get the manual your looking for to your new watch.
http://www.retrevo.com/s/Fossil-FS4283-Watches-review-manual/id/22194dj989/t/1-2/
May 07, 2011 | Fossil Watch - Brown IP Chronograph
I have a fossil watch with ES-1426 3000601 model number. Wanted to know if it's fake or genuine. Where can I find the authenticity of this? A friend just gave it to me.
Be sure it is genuine as the Fossil watches are not in that league to make fakes. Even fake watch manufacturing needs a significant money investment,so, expectations for quick turnaround and investment recovery are common. This would not be possible with fake Fossil watches as the average price is about £70 for original and this is comparably low price in watch market.
Don't be scared away by this- Fossil is good brand: they just using cheap labor and parts, at the same time offering good looking and quality watches to masses.
Rate me, please.
Aug 22, 2009 | Fossil CH2473 Watch for Men
No manual how do I set time?
You have to open caseback and upload the movement number here. Then I might help.
Dec 18, 2008 | Fossil Digital Sport Hologram Display...
Apr 04, 2008 | Fossil CH2332 Wrist Watch
-> Go to fossil.com
-> Customer Care
-> Product Info / Watch Instructions
-> Do a mouseover on the various headlines to see the design of your watch.
-> Download desired PDF file
Problem solved. Thank you!
Aug 29, 2007 | Fossil CH2331 Wrist Watch
Fossil CH2473 Watch for Men Logo
74 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
