How do you tighten or remove the agitator? - Washing Machines
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Please post back with a brand name and model number. All agitators are not alike.
Kenmore 110.24952300. how do you remove agitator
Posted on Aug 23, 2009
    Scholar:
  • 51 Answers
Please follow the steps bellow to remove or open the agitator. It would be highly appreciated if you could mention the make or model of the washing machine.
Unscrew the agitator cap.
Pull up on the agitator.
Fill the tub halfway with hot water if it won't come loose. Sometimes the heat helps release it.
Tap on a small block of wood pressed up against the top of the agitator if it still won't release.
Replace the old one with a new agitator of the same model.
Thank You for contacting Fixya.com
Posted on Aug 02, 2009
Whirlpool top loading cloths washer agitator is loose when it should be turning. how do i tighten it?
Sounds like you might have bad agitator dogs. Remove the agitator cap, theres a 5/16th bolt that needs to be removed then the top of agitator comes off. The dogs are 4 little gears with teeth on them, when they get worn the top half of the agitator doesn't move.
May 09, 2011 | Washing Machines
Washer fills with water but does nothing after that
Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5
Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6
Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch
Feb 05, 2011 | Whirlpool Washing Machines
Washtub will not move
5
6
Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Feb 04, 2011 | Washing Machines
The spin on the washing machine is not working.It turns but very slowly Machine is A Siemens WM16S38368 2 years old
it may be your agitator
5
6
Jan 31, 2011 | Siemens Washing Machines
The agitator in the washer is lose. How do I tighten it up.
remove the plastic cap on the top of the agitator, under that is a retaining bolt, tighten it.
Nov 26, 2009 | Washing Machines
I have a Kenmore washer that has trouble agitating. I took off the cap on the agitator and tightened the bolt that goes into the agitator. This fixes the problem for a while. Pretty soon the agitator...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There are two "bolts" for the agitators (assuming that you have the basic split system) The bottom agitator turns back and forth and the top section only turns one way.
The top section (when you remove the cap) usually has a plastic 1/2" square drive bolt.
If you remove the bolt and top section of the agitator, you should see a second 5/16" stud. under the stud is a rubber washer.
The first thing I'd do is pull both parts of the agitator and look at the splines inside of the lower agitator and the splines on the transmission agitator shaft. If either of them is worn / broken, your washer won't agitate. Also make sure that the two pronged "washer" is in place on the transmission agitator shaft and that the clip that holds it in place is fit.
If the splines are OK, I'd carefully put the lower agitator back on. Check the condition of the rubber washer on the stud. Install the stud and do not over-tighten.
Put the top agitator on tighten the 1/2" bolt carefully. Don't over-tighten.
Beyond that, you may be looking at a clutch or transmission problem.
Oct 07, 2009 | Kenmore Washing Machines
Need to remove agitator on kenmore series 70
Follow these steps for removing the agitator on a Kenmore:
  1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap. Sometimes this is a dispenser cup that simply pops off.
  2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
  3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
  4. Carefully remove the auger (upper portion of the agitator) and set aside.
  5. Remove the agitator by grasping the bottom flange and carefully pulling straight up.
Note: Try to keep all the parts assembled while doing this. In particular, the auger. There are small components inside. In addition, when reinstalling the agitator DO NOT over-tighten the center nut. This can restrict agitator motion and may cause damage. Tighten until snug.
If you have questions, please let me know. I hope you find this information useful.
Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 90 Washer Triple Action Agitator
THERE IS EITHER A 3/8 BOLT OR 1/2 ADAPTER TO REMOVE AGITATOR
Nov 22, 2008 | Washing Machines
Kenmore Washer Model #82881110
Remove the dispenser cap by pulling it straight up. Under the dispenser cap, there may be another cap. If so, remove the center cap exposing the agitator bolt. Using a socket and ratchet remove the agitator bolt and the top half of the agitator can be lifted out as one piece. With the top portion of the agitator removed, grasp the lower agitator by the bottom flanges and pull straight up. The remaining section should lift off the center post. For a helpful illustration of what I'm talking about, go to searspartsdirect.com and type in your model number as "110.82881110". Go to the "Agitator, Basket and Tub" heading. There's an exploded view illustration of the agitator and all the components. If you require parts, all the part number and pricing information is available, as well. I hope this helps you.
PS When re-installing the agitator DO NOT over tighten the agitator bolt. This can cause damage to the agitator and create slow rotation problems. Just make sure you tighten the bolt snug, and then give it about a 1/4 turn.
Oct 09, 2008 | Washing Machines
Eaton Viking Washing Machine
Usually on these machines on the very top of the agitator is a snap-on lid, usually for adding bleach or fabric softener. Unsnap this lid and lift from the top of the agitator. Look down the hole and you should see some kind of nut or screw. Remove this item (make note as to how tight it is JUST AFTER it breaks free). Once this is removed, you should be able to lift the agitator out of the machine. Remove your shirt, and replace the agitator. Replace the nut or screw previously removed, and tighten approximately as tight as it was when removed. Don't over tighten. Replace snap-on lid.
With the unit apart, now might be a good time to clean any accumulated dirt or other foreign material.
Mar 09, 2008 | Washing Machines
Washing Machines Logo
203 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
