Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Green screen I have a jvc 56inch tv i try using the hdmi cable but all i get is a green screen the cable is good and the dvd player are good also
  • pharmD08 Dec 20, 2007
    Same deal, HDMI cable #2, still green screen. I can't even adjust the settings on the bluray player because I can't see squat! Seems to work alright with all the other types of cables.
    President:
  • 1,284 Answers
If the TV works ok using the component,composite and tuner inputs otherwise then the HDMI module is bad.
Posted on Nov 26, 2007
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Jan 21, 2015 | JVC Televison & Video
My tv displays "format not supported"
Too many variables with what you are describing here. How old is the TV and how old is the DVD player. Did you verify that the components were all plugged in to their corresponding colors....blue to blue, red to red, green to green. Is the RGB cable verified good. Another common mistake is to plug the video jacks into ex. VID 1 while the Audio is on VID 2. Make sure they are on the same numbered input and that the TV is on the input your jacks are in. The HDMI may not work because there are three different HDMI types and not all play well with each other. The problem can be fixed with an HDMI converter but gets into more cost. Eliminate above mentioned and repost. I would be glad to troubleshoot you through this.
Mar 12, 2014 | Sony DVP-SR500H DVD Player
Green screen
Try to reset to your Marantz to factory settings, or try the newest Firmware. :)
Jan 21, 2014 | Marantz Audio Players & Recorders
No sound JVC DVD Model#XV-THC5
What type of cable connection are you using from the DVD player to the TV? HDMI, component, RCA, optical? If it's component (red, white, red, green, blue) make sure that you don't have the red video cable switched with the red audio cable. If you're using HDMI or optical make sure your TV setting is set to the particular audio source. If these steps are too simplified, I would check the easy stuff first such as the connections themselves. Let me know what you find out and then we'll proceed further.
Oct 17, 2013 | Televison & Video
DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
Mar 28, 2010 | Sony RDR-GX7 DVD Recorder
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
HOW TO CONNECT IT TO MY CABLE TV.
Connect the cable box to the DVD Input 1 (on the back) or the AV 2 jacks on the front of the DVD recorder using a composite cable (Yellow - Red - White). Use an HDMI cable from the JVC DVD to your TV if it supports it. Otherwise use a component (red-green-blue) cable to the TV.
Mar 10, 2009 | JVC DR-MV78B DVD Recorder
Hdmi Issue
Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
Sep 11, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Jvc tv does not recognize toshiba dvd player sometimes....
Which cable type are you using (component, composite, HDMI...)? If it's composite (the white, red, yellow) it may be in "progressive scan" mode. Check the manual to see how to toggle betwixt the two.
Sep 10, 2007 | JVC AV-27530 27" TV
HDMI input
The green screen is caused by light hitting the back of the tv. Either move the tv to a location where direct sunlight will not hit it or put up strong curtains. As for fixing the problem, do a search for JVC green screen reset on AVS Forum, its easy to do just dont have the info with me now. Keep in mind if direct sunlight hits the back of the tv it will do it again. I have put up some good curtians and ensure not to open them when watching the tv. Hope this helps. I am Hayward, have a nice day.
Aug 21, 2007 | JVC HD-56G886 56" Rear Projection HDTV
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
437 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
