Question about Hyundai HLT-3272 32 in. LCD Television
Rca L32WD22 won't turn on...is there a fuse? If
Rca L32WD22 won't turn on...is there a fuse? If so...where is it?
  • Anonymous Apr 01, 2014
    Lost remote need to change input on rca l32wd22
  • 39 Answers
Hello
did you see the standby light? if no you have problem in main power section maybe the fuse is blown you can locate the fuse at the power main board, or if the standby light is light up the problem is the inverter power supply and this section is need to diagnose to find the defective parts...
Angel
Thanks...
Posted on Aug 02, 2009
HOW TO GET AN USER MANAUL FOR A RCA MODEL L32WD22 TV
I suggest you try the support section of the manufacturer's website where user manuals are often available for free download.
Feb 11, 2015 | RCA Televison & Video
I have no remote for an rca l32wd22 hdtv lcd tv and cannot find the inputs to change to HDMI?
Unfortunately, the L32WD22 doesn't have an Input button on the front panel of the TV. You need a remote control that matches the Input code for the remote. Here's one link to a remote that should work: http://remotes.com/store/rca/l32wd22.html . Other universal remotes may work if you find the correct code if the remote has an Input or Source button.
I hope this helps.
Apr 16, 2013 | RCA L32WD22 32 in. LCD HDTV
RCA L32WD22 made popping noise, now no picture or sound
Power supply is most likely and only boards are sold, RCA is not always easy to get parts and tech assistance is almost zero
Dec 23, 2012 | RCA L32WD22 32 in. LCD HDTV
TV will not turn on
There are often fuses. If you are handy get a hold of the wiring diagram and see where the fuse is. You should see it pretty close to where the powercord comes in to the back of the unit. Pop the fuse out and run to radio shack for a replacement.
Dec 18, 2012 | RCA L32WD22 32 in. LCD HDTV
When i turn my 32'' rca flat screen on the red light is flashing but it would not come on ,what is causing that to happen ?
Power Supply problem, had the same problem, could not find a Power Supply board replacement even on ebay. They had a capacitor replacement kit, here on ebay http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
Used that, and it worked.
Dec 11, 2011 | RCA L32WD22 32 in. LCD HDTV
RCA L32WD22 with no picture.
The backlight has failed. May be the power supply for it, the inverter board or the lamps. Not something you can fix unless you are a tech.
Mar 10, 2010 | RCA L32WD22 32 in. LCD HDTV
I have a rca l32wd22 screen weht black with no
Aboyd992,
Take your tv to a service center and ask them to fix it. If they cant...
Have them make out a work order and then you call 1-877-297-8391. The people at the other end ot the tele number will give another tv
Jan 09, 2010 | RCA L32WD22 32 in. LCD HDTV
My rca l32wd22 will not power up what do i do
First place to look is the main power supply module for simple thing like fuse, then look for 5V standby, you must have at least this standby voltage. This 5V (should always be there with the TV on or off) is supplied to the main board so when you turn on the TV, the main board will send the ON signal to the main power supply to supply voltages to other circuits.
Nov 03, 2009 | RCA L32WD22 32 in. LCD HDTV
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
Hyundai HLT-3272 32 in. LCD Television Logo
1,240 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
