Question about GE Ovens
F-2 code I'm getting an f-2 code and I've tried all the circuit breakers in my panel, but none seems to work my oven. Help! THe beeping is killing me!
  • 6,784 Answers
HI. this code can come up for two different reasons. it could during a bake session or a cleaning situation as well. I will list the details below.
During Baking(((f2)))
During a baking session, if the control senses an active oven temp above 615f-630f, this code will appear.
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
During Cleaning(((f2)))
During a cleaning session, if the control senses an active oven temp above 915f-930f, this code will appear.
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Posted on Aug 02, 2009
F24 code
In some cases I have had to replace both the touch pad and power relay board. Expensive! HOWEVER, I have, on occasion, found the wide ribbon from the touch pad to the relay board to be at fault. I have not found replacements for these as of yet. I have been able to "open" the ribbon to clean the contacts within and reassemble it to find everything working. Needless to say, my clients have been extremely happy with my ability to do so, saving them thousands if having to replace the entire unit.
I found the bad connection when the lighting was dim and I saw a "flash" at the point ribbon it inserted in the end piece. Hope this helps.
Jan 23, 2014 | Thermador Ovens
Got F9 on Amana range model ACS3350 while trying to clean oven. The door is locked and got constant beeping with F9 error code. Powered off oven for 10 minutes and powered on, still getting the door...
Shut off the circuit breaker to it for FIVE minutes, then back on. If the problem persists then do the following:
A latch locks the center top INSIDE of the door during cleaning.
Run a piece of semi-stiff, flat object, like a cardboard strip that is in L shape behind the top lip of the door from RIGHT TO LEFT. You may need to push it along with your finger jambed in there when it reaches the latch. With a little push the latch should open.
Try to run the oven, if F9 shows again, press cancel Oven to quiet it. The Lock state is still in place. Move the latch hook manually all the way to RIGHT. Then shut off the circuit breaker for FIVE minutes, then back on. The oven should work ok.
If this fails again try the five minute shut off with the latch in other starting positions.
If none of these work then the latch mechanism, or it's motor is really broken. Replace or ditch and never buy Amana again!
Sep 01, 2011 | Amana AOCS3040SS Electric Single Oven
Jenn air wall oven, 18 years old, tried to clean, code f-8 came on, oven beeps, hit clear, beeping comes on in several minutes, and oven will unlock, have tuned circuit breaker off and back on, did not...
The oven remains locked when internal temperature is hot enough for the cleaning cycle. If it unlocks after the temperature comes back down, it seems to be working properly.
Feb 06, 2011 | Ovens
The display panel is blank, and none of the buttons work. It had been working earlier in the day, but is no longer functioning. Is there a breaker button?
Hi, Check to see if there are any lights working, such as the ones that come on when you open the oven doors. If there is absolutely no power going to the unit, check the household circuit breaker panel that services the oven.
An oven works at 240 volts so the circuit breaker for it will be a double breaker, similar to the ones
electric water heaters or air conditioning units. It may have tripped. If it is tripped, then
the lever connecting the two sides of the breaker will not line up with other breaker switches in the
breaker panel. If that is the case, shut down the breaker completely and then after about 10 seconds,
turn it back on. If it will not stay on, there is an electrical problem in the circuit going to the oven or the oven itself. Hope this helps. Let me know if your need more help.
Best,
Mark
Dec 30, 2010 | KitchenAid Architect ® II KEBS208S...
Whirlpool Gold double oven - started beeping then all lights on the control panel went out. Reset the circuit breaker which makes the oven beep but still have no lights. Oven will not operate.
I was just looking over a manual for a late model double oven. Their is a thermal limit going into the controls that will open if the temp rises enough to harm the controls. They look like this one.2605a73.jpg That kills all power to the control and you will see nothing on the display.
This manual will give an idea where to look:
Late model double oven
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 27, 2010 | Whirlpool GBD307PDS Electric Double Oven
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
My oven keeps beeping and saying to call service and it says do not use the oven... I am not using the oven but the beeping is driving me crazy..is loud ...can someone help before I kill myself?
Have you tried switching the oven off at the wall switch (if there is one)?
If not you should be able to switch it off from the circuit breaker/fusebox by switching offf the oven circuit.
Nov 30, 2008 | Ovens
My oven is beeping!
Try turning it off at the mains, then whilst turning it on, press and hold the cancel button.
Check the fuse and any other electrics on the same ring; eg. Washing Machine - this can indicate that the circuit breaker has tripped, replace any fuses and check integrity of electric on that circut, then flick it back on.
Jan 26, 2008 | Frigidaire GLEB27S7A Electric Single Oven
Whirlpool GBD307PDS Double oven stopped working.
The beeping sound is a fault code. Problem is it isn't listed. In either the top or bottom oven panel there should be a service sheet. The codes are located on this service sheet.
Jan 22, 2008 | Whirlpool GBD307PDS Electric Double Oven
Ovens Logo
129 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
