Question about Mitsubishi WS-65807 65" Rear Projection Television
Ok i have tried to converge the colors numberous
Ok i have tried to converge the colors numberous times ad even reset them back to factory settings and the television keeps doing the red and blue shadowing of everything what else can i do to make it stop?
  • Charlotte Grandbois Aug 02, 2009
    thanks but i dont even know where to find the closest technician to repair it for me i just moved here to williston,ND
    thanks :) I think i have the biggest television in this town or even close to here though lol but I will check around
    Brigadier General:
  • 4,090 Answers
I don't know what you were advised to do before, but if you have played with the convergence and you stoill get shadowing it is probaly one of the chips on the board. I suggest you call a service tech as you could be making the situation worse by fiddling in an area of High tension power
Posted on Aug 02, 2009
  • dennis bullard Aug 02, 2009
    oK I cannot help you there either I am many miles away from you in australia.
    Yellow pages or whatever you have there should be helpful to find Tv repair technicians listed. I would be even asking around at the nearest town center where a TV repair shop is located.
    hahaha well that will be an eye opener for the locals may be you should put it on display and charge admission to cover the repairs when its fixed
Intermittant white faded picture
Since it is intermittent it will likely be hard to find but here is some general information and ideas since I have worked on hundreds of the Mitsubishi sets.
If the issue was with just one of the 3 tubes the screen color (background) would change--so not that.
These sets are prone to Glycol issues (coolant leaking from the tubes) but since once that happens it does not take time or even come back that is not the issue.
This set has 3 hidden menus--
One: advanced Convergence adjustments that can be saved.
Two: Adjustment menu(keep out of that one!)
Three: Option Menu
That menu allows a hard reset of the entire set that sets all settings back to factory.
The convergence is not affected and it has been known to cure all sorts of odd issues like no sound, inputs not working, odd brightness and video issues, and others.
If you have labeled video inputs from 1 to DVD etc those will be removed, set will come on in air band on channel 3 so will if using cable have to switch back to it and auto program channels etc.
It essentially puts the set back to the condition setting wise that it was when new in the box.
The only reason I suspect this could help is if the set has developed some kind of processor glitch it will reset that also.
No harm can be done to try it---it requires the Mitsubishi remote and a four digit number code.
If interested I will give you a link to the full manual (free to download) and the page number with instructions for the OPTION menu entry and reset.
SD TECH
Apr 21, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Red tint on screen
u shoud reset your setting try to on
Jul 27, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Multipoint blue convergence cannot be adjusted
Sound like you need to replace the STK's and any blown pico's on convergence board.
Jan 20, 2008 | Philips 60PP9202 60" Rear Projection...
How do I fix the color on the tv?
If the model number is correct here look on the back of the set not for model number but chassis number---suspect that is PTK195.
If that one and convergence is skewed fairly bad--easy repairs--just need a meter to check a few parts to know. Set has a common problem where one of two diodes shorts and convergence only partly works.
Apr 09, 2012 | GE 46GW947 46" Rear Projection Television
Adjusting color,to much red and green
Reset the colors back to factory setting,that still a problems? Ur tv convergence are dead.U know how to solders?Must replaced 2 STK convergence ICS and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 17, 2010 | Samsung HL-R4264W 42" DLP HDTV
Reset the date and time to original factory settings
Please follow the steps below to reset the setting to default...
1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sx200resetscreen.jpg 3. Using the arrowdownbutton.gif button, select [Reset All..] and press funcseticon.gif. sx200menudirection.jpg 4. Select [OK] and press funcseticon.gif. sx200resetconfirm.jpg
  • Settings cannot be reset when the camera is connected to a computer or to a printer.
  • The following cannot be reset:
    • Shooting mode
    • The [Date/Time], [Language] and [Video System] options in the setup_icon.gif(Set up) menu
    • White balance data recorded with the custom white balance function
    • Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
    • Newly added My Camera settings
Feb 19, 2010 | Canon PowerShot SX 200 IS Digital Camera
Color is off on my tv im seeing colored shadows how do i reset that without a remote
Ok, it is a Mitsubishi-I see you have posted it here two times with different model numbers.
What is actual model number of your set--It sounds like a convergence problem and I can tell you what exactly is needed to fix it.
get back to me.
sd tech
Nov 09, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
Mar 15, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Convergence trouble
You most likley have bad convergence amps and two burnt resistors.Part# STK392-110.Convergence circut is located @ frot of set behind speaker grill.The only reset is in the customer menu listed Convergence reset.
Jan 12, 2009 | JVC AV-65WP74 Rear Projection Television
CONVERGENCE
You need to replace both convergence ICs number STK393-110 they are available at the following link and they provide free instalation instructions with pics so you can do the repair yourself which takes about 40 minutes start to finish. heres the link
http://servicemanuals.vstore.ca/
May 15, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
106 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
