Question about Whirlpool ED2GHEXN Side by Side Refrigerator
How to change the water filter on a whirlpool refrig model # ED2VEXVQ00. the owners manual has no directions.
  • alan_loizeau Aug 02, 2009
    the owners manual was no help in determining how to remove the filter element. the wife figured it out in 5 minutes.
    next to the filter cap, on the kick board, is a button (on the left side of the filter). puch the button (its hard to push) and pull the cap straight out WITHOUT twisting. after the filter is removed, the cap twists off. install the cap onto the new filter and push filter back into its hole. the cap will only allow you to install the filter with the correct alignment. keep pushing until the button 'pops' out and locks the filter in place.
    done. enjoy cold beverage of choice.
    President:
  • 1,136 Answers
The filter is located in the kick plate. There should be a handle you need to turn and le filter will release. The handle aprt of the filter will seperate from the filter and need to be used on the new filter.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Aug 02, 2009
  • Victor
    Victor Aug 02, 2009
    I am glad you got the filter changed. They don't give you much info in those manuals. They want you to call them to fix it.
    Please feel free to rate my responses to you so that others as well as myself will know how I am doing.
    Thanks
    Vic
What type/model/ brand of water filter do I need for the Whirlpool Roper side-by-side refrigerator with the model number: RS25AGXNQ00
There is a generic type of water filter that fits all Whirlpool and KitchenAid refrigerators with a water filter located in the base grill below the door.
it looks a bit like this: http://www.partselect.ca/11722132-2-M-Whirlpool-EDR5RXD1-Water-Filter.jpg
Here is one on amazon: Amazon com Replacement Roper RS25AGXNQ00 Refrigerator Water Filter...
Sep 05, 2016 | Whirlpool Refrigerators
Whirlpool filter
Here is your owner's manual:
http://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10366204.pdf
On page 13 it states, "The water filter is located in the upper right-hand corner of the refrigerator compartment."
Apr 16, 2014 | Whirlpool Refrigerators
My ice and water has a strange taste. Its model number RS22AQXM001 and its a Roper by Whirlpool. Does it have a water filter on it that needs to be changed?
I'm sorry according to the parts braekdown for that model number their is no builtin filter..you could add a external one to the water supply line into the refrig.
GENE
Sep 04, 2011 | Roper Refrigerators
Where the water filter whirlpool gold model no GS6SHEXMQ00 located? the last home owner lost the manual.
The base grille water filter cartridge is located below the freezer
compartment door. Depending on your model, you may have a
filter that is installed behind the base grille or a filter that
is installed through the base grille
This should be the right manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202188772.pdf
Mar 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a friend with a Whirlpool ED5PHAXMB00. It's producing ice, and dispensing ice, but no water will dispense. She changes the filter evey time the light comes on, so am thinking it's not that. Have...
Some refrig's , water goes to filter first , some thru water valve first and then the filter . On this model , it goes to the water valve first , then the filter .
1) never change the filter just because the light says to . Only replace when icecubes get small or when water flow from dispensor slows . A filter can last 6 mths- 1yr. and sometimes longer .
2) the resevoir is in the refrig section , behind the lower crispers
3) the water valve is probably the problem
pt# 4389177
Sep 09, 2009 | Refrigerators
Ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Where is the release button for the whirlpool gold conquest water filter?
your filter either has a release button directly next to the filter within the kickplate. teardrop shaped button you push, or the only other filter hpusing requires that you twist teh filter out by turning counterclokwise it to is located within the kickplate under the refrig door
Mar 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water filter change
the water filter is located in the ceiling of the refrig compartment there is a thumb relaese that relases a cover to expose the filter. simply trun the filter counterclockwise a 1/4 turn then pull down and it will relase. btw here is a part number for your filter in case you need it. UKF8001AXX thx peyton
Jan 26, 2009 | Jenn-Air JCD2295HES Side by Side...
Water filters
Go to www.whirlpool.com/accessories or call 1 800 901 2042 and have your model no. They should be able to help you either way!
Aug 14, 2008 | Whirlpool GS6NBEXR Side by Side...
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Whirlpool ED2GHEXN Side by Side Refrigerator Logo
509 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
