Question about HP Pavilion dv7-1130us laptop
HP Pavilion not playing Youtube
I have a HP Pavilion DV5, up until recently everything has been OK with it, although the machine has always caused some agro (for example the unique selling point being the bluray player didn't work until I had a friend spend time updating the brand new machine). The past few days I have been unable to view youtube videos, I get the message "an error occurred please try again later"
I'm banging my head against a wall now with this problem, I have researched it on the net an the most common advice received was the following:
Uninstall Java and Adobe Flash, Reboot, re-install both programmes via the official websites, reboot and bob's your uncle. In my case though bob isn't my uncle, and this didn't work!!
I used the windows un-installer via control pannel to remove old versions.
I'd really appreciate any detailled guidance on this urgent matter, I work away most of the time and youtube is the one thing that keeps me going sometimes!!!!!
Kind Regards,
Phil
  • 748 Answers
Hello
I've seen this often with XP and Vista. I'm posting the Microsoft instructions. Although this isn't always the cure, it is most of the time. Good Luck
  1. Click Start Collapse this imageExpand this image HP Pavilion not playing Youtube - vistastartbutton.jpg, type regedit in the Start Search box, and then click regedit in the Programs list.
    Collapse this imageExpand this image securityshield.jpgIf you are prompted for an administrator password or confirmation, type your password, or click Continue.
  2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  3. In the right pane, right-click UpperFilters, and then click Delete.
  4. Click Yes to confirm the removal of the UpperFilters registry entry.
  5. In the right pane, right-click LowerFilters, and then click Delete.
  6. Click Yes to confirm the removal of the LowerFilters registry entry.
  7. Exit Registry Editor, and then restart the computer.
Note After you remove the UpperFilters registry entry and the LowerFilters registry entry, you may lose functionality in certain programs such as CD recording programs. In this scenario, you must reinstall any affected programs. If the problem recurs, contact the program vendor to determine whether an update is available for the program.
Posted on Aug 02, 2009
Can a hp pavilion dv5-1127cl power port work in a
Hi there
I think in this particular case it might not be wise. The power blocks for these two appear to be different wattages (65 & 90 respectively) and also the connector to the laptop does not look to be the same, in which case damage to the power inlet socket of one or the other laptop could occur if you tried to fit it too energetically. I did find this eBay seller who gave quite a list of compatible laptop models for the power supply he was selling, but although the DV7 series is there, the DV8 series isn't.
AC Adapter Charger for HP Pavilion DV5 1127CL DV5 1128CA Power Supply
I think you would be better to get a power supply that exactly matches to prevent potential future problems.
Perhaps not the advice you were hoping for, but I would get a new one for whichever machine you need it for, and make sure that compatibility with your machine is specifically stated.
Cheers
Nov 10, 2014 | Computers & Internet
I have a question HP Pavilion DV5 Full
That is you WLAN card (Wireless locale area network card) it is what makes the laptop conect in hotspots.
Oct 23, 2013 | HP New Pavilion DV5-1000 DV5 Series Silver...
I need to replace the hard drive of a dv5-2129wm
Step 1:
How-to Replace the Hard Drive for an SSD on a HP Pavilion dv6 http://www.youtube.com/watch?v=QQx7PlIXFuE How to Change A Hard Drive In A HP Laptop http://www.youtube.com/watch?v=650mXGa-kDY
Feb 04, 2013 | HEWLETT-PACKARD Garden Dreams Pavilion...
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
http://www.buy.com/prod/90w-laptop-ac-adapter-charger-for-hp-pavilion-dv5-1125nr-dv5-1127cl/q/loc/101/215845345.html
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
Jan 13, 2011 | HP Pavilion dv5-1125nr Notebook
Problems with HP HP Pavilion dv5-1159se 15.4
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 29, 2009 | HP Pavilion dv5-1159se Laptop
Mi laptop is playing a tapping sound
the sound could be a stuck up keyboard, try looking at your keyboard...hope this helps..ITTech7574
Aug 31, 2009 | HP Pavilion dv5-1138nr Notebook
Can't play DVD on VLC on HP Pavillion dv5 running Vista.
problem with DVD drive, HP has this problem, not only that, Drives for laptop doesnt suit to work long. if under warranty, try to change that as soon as possible.
Aug 12, 2009 | Computers & Internet
HP Pavilion dv7-1130us laptop Logo
110 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
