Question about Kenmore Washing Machines
There is not enough water in my top loader kenmore 600. I'm at the cottage, maximum water pressure is 60 pounds
    Top Expert:
  • Kenmore Master
  • 49,110 Answers
Could be a defective level sensor or control board
Posted on Jun 14, 2018
duby1990
  • 370 Answers
SOURCE: kenmore oasis top-loader problem
Use the Whirlpool affresh tablets. Use all three the first time in hot water on the longest cycle. Then use one a month in hot water ect. and it will keep your washer smelling better.
Posted on Nov 14, 2008
localwonder
  • 6784 Answers
SOURCE: ont stop filling with cold water
Hi. the pressure sensors in the water valve assembly appear to be damaged. you will need to replace the inlet water valve assembly in this case asap.
This is solenoid failuer. (basic water valve failure this case)
Posted on May 31, 2009
  • 46 Answers
SOURCE: kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Posted on Jun 27, 2009
wracefans24
  • 1985 Answers
SOURCE: oil pressure gauge shows 60-80
the oil sending unit that screws in the block beside the oil filter may be faulty,
the worst thing would be the oil pump its self the regulator valve on it
Posted on Jan 26, 2010
  • 1937 Answers
SOURCE: my top loader kenmore is noi spinning
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Four possibilities: (Ranging from easiest to messiest)
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the
washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section
on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf8525712
2007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using
an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the
washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?
newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor
coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6
inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to
put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they
don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you've tested the Lid Switch and the Motor Coupler is fine, and the clutch bands and springs are OK the problem could
well be the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for transmission operations on top load direct drive washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b
0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into
spin mode.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the
Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to
have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and
gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator
uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two
clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8
screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic
cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't
go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Jun 01, 2010
Front loader machine / heavy duty wash cycle does not work. It will start then something like a flashing F (something) appears
A few basic checks to do before calling someone out to look at it....
Is the water pressure turned on to maximum?
have you thoroughly cleaned the pump retun and filter baskets?
have you cleaned the rotating wash heads?
Try this and give the machine another go....
Dec 17, 2010 | Kenmore Dishwashers
My top loader Kenmore type 111 is working fine until it get to the spin cycle. It won't spin and it makes a really loud buzzing sound. like a weedwacker or something. Help!!!
verify that hot and cold water are not reversed and BOTH are turned on. Sounds like water is shut off. Water valves are noisy without water pressure.
Sep 06, 2010 | Kenmore 22642 Top Load Washer
Kenmore top loader 500 - water does not run when knob is pulled out to start cycle
Either a bad water valve or pressure switch. If you can't get cold or hot, it most likely is the pressure switch.
Please rate solution
Sep 03, 2009 | Kenmore Washing Machines
Ont stop filling with cold water
May 31, 2009 | Kenmore Washing Machines
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer Top Load Series 60 won't drain
The water pump is a belt-driven device actuated by a clutch. Your problem could be:
1. Stuck pulley - break it loose and WD-40 it
2. Broken belt - replace
3. Bad clutch - call repair or replace
There is almost nothing that can go wrong in the pump itself. It's probably one of these three.
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Freezer not staying cold
the temp control thinks its cold enough to stay off so you need to have the temp in home warmer so it will cycle / atleast 60 / larry
Dec 12, 2008 | Frigidaire FRT21H8 Top Freezer...
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Open Questions:
Washing Machines Logo
855 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
