Question about Garmin GPS
It got thrown into a wall and broken,face plate, on of switch, and some yellow strip broken
    Problem Solver:
  • 11 Answers
Well you solved this one yourself, it's broken now.
Call garmin, see if they will fix it.
Posted on Aug 02, 2009
Replacing a switch on a ceiling fan
Wall mount. Cut the power to the switch by tripping the breaker at the "fuse box". You will need help to see what breaker controls that lighting circuit.
Get new switch,remove old switch from wall mount and note the color coding of the wires.
There will be screws that attach the power wires to the switch and
wires that go to the fan.Power wires are one black and one white. The other wire is a green ground wire.
Remove the wires,one at a time and connect to the switch,IF there is enough wire length to do so.You will need pliers to yank the wires out.
The stripped,bare wire at the end should go on the new fan switch so when you tighten the wire end,the wire end tightens onto the terminal clockwise.
If the stripped end is broken off,strip another 3/4" of wire and wrap the wire around the terminal,clockwise.
You MAY test the switch B-4 you put it back into the wall.Be careful of the "hot" black wire.
Click the circuit breaker back off and install into the wall box.
Jan 18, 2013 | Hunter 52" Ceiling Fan With Light And...
I provided 12v from car the security red light blinks, but when I attach face plate the stereo is dead?
do you have power going to both the yellow and red wires????????
yellow is constant power and red is switched power (ignition).
May 31, 2010 | Audiovox ACD-22 CD Player
Re:D-Link dgs-1005d mounting plates
For this as per my knowledge there are no extra mounting plates comming commercially. But itself having some mounting tools such as wall plug, screw etc. in it's package....and for permanent installation if you need it very much you can order such thing in turning workshop...but try to use it in friendly environment....because those are heat and hazard sensitive for heavy duty.....All the best.
Oct 20, 2009 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
'06 Boulevard c50T - how do I replace left frnt turn signal
replace the turn signal which should come with a new wire and replace clear down to the wire connection(should even be a clip connection). don't worry about re-soldering
just order the new signal, wait for it to arrive and see what you're getting into before messin wit it
Sep 20, 2009 | Suzuki Boulevard C50T Motorcycles
I have a GE Profile JVM1790 microwave that needs to be installed. However, it will sit in front of a 3/4" thick granite backsplash that I would rather not drill holes through. Would it be safe to mount...
The front weight hangs from the cabinet above the microwave, the rear weight needs support also. It is intended to be fastened to two studs. If the granite does not go all the way up to the cabinet above, install a wood spacer, the same thickness as the granite, then extend the wall plate, at the corners, with some flat stock aluminum strips, available at most hardware stores. Fasten the aluminum strips to to wall plate with short machine screws. - If the granite goes up to the cabinet bottom, shim out the bottom frame of the cabinet to the face of the granite and use the same aluminum flat stock to extend the wall plate up to the necessary location.
Jul 06, 2009 | Microwave Ovens
Face plate went out on my pioneer deh 6800mp
There is a fine strip that runs from the face to the circuit board. It is possible that face has gotten dirty just needs a can of compressed air or the circuit board has failed inside the face. The face plate is very easy to take apart and put back together, just make sure you don't lose any pieces ;) Good luck!
Jun 11, 2009 | Pioneer DEH-P6800MP CD Player
Pedals broken on xbox 360 MS wireless wheel
I've see a lot of posts where people have had issues with the Microsoft racing pedals not working properly. Usually the throttle just races away when it is suppose to be at idle. I had this problem and after taking apart the pedal set more than once to try and fix it - it's made so cheaply - I gave up.
So, if you want a good fix, here is what I did. I got a set of Madcats 2 pedals, which are X-box compatible (craigslist) - other pedal sets may work but then you would have to figure out the wiring on your own which took me considerable time NOTE: These do not have to be the Madcats pedal set from the force feedback type, just the standard pedal set will work.
I went to home depot and bought a wall phone jack. I then took the bottom off the Madcats pedals (the Phillips screws are under the square rubber pieces which you can peel off with a small blade - common screwdriver) and you will see there are 4 wires going to the cable that normally plugs into the MC2 wheel. Pop the face plate off from the phone jack but don't throw it away and cut the cable on the inside of the MC pedal set about 2" from the grommet. You can pull the grommet out of the slot and discard the cable. Carefully strip the insulation on the 4 wires (Brown, Yellow, Blue and White). I've done the hard part, which took me about 5 hours so here are the correct wire color match-ups. The phone jack has Green, Black, Red and Yellow wire hook-ups. Connect the MC-Yellow to PJ-Green; MC-Blue to PJ-Black; MC-Brown to PJ-Red;MC-White to PJ-Yellow. Now you can plug in the phone wire connection from the wheel into the phone jack and try out the MC Pedals. Much better? What I did next was cut a hole in the back of the MC pedal case (make sure it is not in-line with where the bottom plate weight goes. I used a hole saw just smaller than the phone jack and then used a razor knife to form a good fit fro the phone jack. Remember the face plate? Get yourself a good pair of sturdy Scissors and cut around the circle on the face plate. Now put the phone jack in the hole you made from the inside of the pedal housing and snap that little disk you just cut out from the face plate onto the phone jack from the outside of the pedal base. Now you may want to glue the phone jack in place on the inside of the pedal base just so it stays put. I used epoxy putty because it kneads like play-do and is easy to push on place. Also it sets up in just a few minutes. Now just put the bottom plate back on the MC pedals and put the screws back in. You will find that the MC pedals do not have the same problems that the Microsoft pedals did like the sticking throttle problem and they are much more responsive.
May 20, 2009 | Microsoft Wireless Race Wheel 2 for Xbox...
Remove Intermatic 60 min. wall timer face plate only from wall
That knob should just pull straight off. Check to make sure there isn't a tiny set screw on the side, but otherwise you can pull it off and remove the cover plate.
Jan 23, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
I have a programmable thermostat. The LED reads Replace batteries. The face plate has fan switch, a system switch, two arrow keys that are separated by three little function (set, hold, and run). HELP!!...
There is a base plate that is screwed to the wall. The face of the thermostat should come off from the base. Usually the batteries can be found back there. Some times a little tug will get it off the wall. Other models have small plastic release clasps that when pushed in will allow the unit to come off.
Jun 30, 2008 | Honeywell Heating & Cooling
No Power to face plate
Hello James,You missing a Major supply to the Face,Take a Test lite and Ck to see if your getting voltage on the Memory wire Also ck Fuses ttech
Jul 20, 2007 | Kenwood KDC-2019V CD Player
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
