I have a Brother mfc-8440. It prints light on the
I have a Brother mfc-8440. It prints light on the right hand side but great on the rest of the document. I cleaned it out and changed the drum / toner and same problem. What do i need to do?
  • cen17794 Aug 02, 2009
    Where would the Corona wire be located?
  • 1,959 Answers
Usually when it prints light on one side and normal on the other, it's either the drum (which you replaced) a dirty corona wire, or the toner is unevenly distributed in the cartridge. You can removed the toner cartridge and gently drop it from a distance of about 4-5 inches to dislodge any caked up toner. This is normal in a cartridge that has sat a while or if the fax machine is in a room with high humidity.
Hope this answers your question and best of luck.
Greg
Posted on Aug 02, 2009
  • 1 more comment
  • Greg Margossian
    Greg Margossian Aug 02, 2009
    Below is a picture of the corona wire as it appears in your machine. To clean you take the blue tab and slide it back and forth along the wire and place the tab back in its home position.
  • Greg Margossian
    Greg Margossian Aug 04, 2009
    Apparently there's an issue with pictures right now. Here is the diagram again.
  • Greg Margossian
    Greg Margossian Aug 11, 2009
    Kindly rate the solution you've been provided if you feel it answered your question. Thank you very much.
Broken Hinge on Left side
Go to: www.partstore.com. You can look up and order the hinge from them.
Apr 11, 2009 | Brother MFC 8440 All-In-One Laser Printer
Brother MFC 8440 makes very loud noise when printing/copying
Very commonly a broken gear on the right side of the fuser. Replace the fuser and this will fix your issue. Let me know if you need a part number and pricing.
Dec 20, 2008 | Brother MFC-8440 All-In-One Laser Printer
Scan from brother MFC 8440 to pc
you need to make sure that the brother printer is et as the default printer
Dec 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Bad Drum?
Yes, printer drums work under photoelectric rules and any exposure to light can affect their performance.
Nov 03, 2008 | Brother DCP-8040 Copier
Replacing Brother MFC-8440 Fuser
To remove the fuser - remove the tray at the bottom and the back tray (4 screws, 2 either side) lift out the phone line box on the right (looking from the back - 2 screws) and swing it out of the way (careful as cable isn't too long) 2 screws either side of the fuser (long black object at the bottom) unplug the halogen lamp (white plug on left) and small 5 wire plug on right, and lift out fuser unit.
Aug 25, 2008 | Brother MFC-8440 All-In-One Laser Printer
My MFC8440 Cover Left Hinge Brocken
Very common part any brother dealer can get it. Ring brother to find closest dealer about 20 bucks
Dec 06, 2007 | Brother MFC8440 Remanufactured Laser...
Brother mfc 8440
menu * 2 8 6 4 super quick then 01, is full reset... warning all settings will be lost
Nov 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440 "printing" problems
Hi
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Regards
Lindsay
Nov 15, 2007 | Brother MFC-8440 All-In-One Laser Printer
211 people viewed this question
jasbo
jasbo
