Question about Cosco Alpha Omega Elite - Hammer Print
How do I get the buckle back on? - Cosco Alpha Omega Elite - Hammer Print
Please I washed the cover and I can t put it back on help
Posted on Aug 03, 2009
Tip
Middle seat belt buckle tip for booster seats, car seats, and large humans.
In trying to fit a booster seat into my 2004 Honda CR-V, I realized that the CRV has the belt buckle in the middle of the seat. This is a big problem for someone using a child seat in the middle seat as the buckle receptacle is completely covered by the booster seat. I thought about buying an extender but realized it wouldn't completely solve the problem. After much thought I came to the conclusion that the buckle receptacle could be moved to a new location without compromising any safety of the belt. I first pulled the buckle receptacle all the way out and then cut the fabric to enlarge the hole from which it protrudes from the seat. Then I pushed it through the hole and back into the seat with the head pointing towards the window and outer edge of the seat. After flipping the window seat out of the way I was able to peel the fabric away from the bottom edge of the middle seat enough to reach in and retrieve the belt receptacle. It was a little tight but I was able to buckle the belt and use the seat belt to pull the receptacle through this new "hole" and VOLIA the belt receptacle is now in a better position to the side of the middle seat. You can now used a booster or car seat or put a fully grown human in this seat and buckle with ease.
on May 20, 2015 | Cars & Trucks
How to adjust buckle
Slide the buckle back and lift the one side out and move it to where it should be. Put the buckle back to whee it should be
Aug 23, 2011 | DR Scholl's Dr. Scholl Dr.Scholl Shoes
How do I adjust dr scholl original exercise sandals? I can't get the slide to move
There is a buckle that moves to the side. grasp it by the edges and move it back towards the edge. Once the buckle is clear of the pin, them adjust the upper to fit you and slide the buckle back over the pint.
Jul 26, 2011 | DR Scholl's Wood Exercise Shoes Shoes
How can you change the straps on a bugaboo frog seat frame.. they seem to be stitched on and i cannot see a way to replace them
The straps are built in and Bugaboos solution is buy a new seat. The Bugaboo uses the same plastic buckle components as the Mountain Buggy, Mountain Buggy sell these as separate parts. If you want to unpick the buckle end and sew back new buckles thats the most economical solution. YKK the international Zip maker also have similar buckle systems.
May 12, 2011 | Bugaboo Frog - Black Stroller
Washed and need to put buckles back together
Always make drawing and notes of any componentry no matter hw suimple before you take it apart.
Imagine the dimensions of the baby/child in the seat to coordinate the right lengths of buckle hasp sections to required to the buckle tongues [we can term them].
Sep 19, 2009 | Evenflo Big Kid Booster Car Seat - Napa
Winnie the pooh graco car seat how to put the arm straps back together after washing
I had the same problem, so what I did was look at the first picture from walmart.com's page with this car seat.
http://www.walmart.com/catalog/product.do?product_id=10843110
I noticed where the straps went through the restraint systems, and remebered that I took the bottom ones out last, so I'd put them in first.
Then I threaded the straps through the buckle parts that snap to the bottom buckle, up through the buckle parts that snap together, then back through the holes in the cover and seat at whatever height your infant is. After that you secure it in the back like the sticker at the side indicates :)
I hope that's clear enough!
Jun 17, 2009 | Graco Nautilus 3-in 1 Car Seat
Seat belt buckle receiver will not accept buckle. The latching mechanism is stuck open and doesn't recede so the buckle (male) can't insert properly
If it's not a coin, look inside the buckle again, compare it with a properly working latch. If you see something inside the broken latch that looks like it may be protruding out from the back, try pushing it back with a flathead or key, then pop the push button back up with the same tool you used... I have to do this each time I get out of my truck because the spring is broken. It still should work fine, it's just missing a spring that reset the latch to it's resting position. If you're still skeptical about it though, it's like a 25 dollar fix with installation.
Aug 04, 2008 | Ford Ranger Cars & Trucks
Cosco Alpha Omega Elite - Hammer Print Logo
97 people viewed this question
Top Cosco Baby Gear Experts
Jennifer Rock
Jennifer Rock
thegtw
noel
noel
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
