Question about Kenmore Freezers
WATS COLDER FROM 1 TO 9 ON MY FREZER - Kenmore Freezers
  • 358 Answers
The higher is the colder.
Posted on Aug 02, 2009
I have a kenmore freezer upright large is 6 colder or 1 the coldest
The higher number is colder and the lower is warmer....or 1 warm and 6 coldest...
heatman101
Aug 28, 2010 | Kenmore Freezers
How to make my freezer colder
Hi, some thermostat control knobs and directions to make it colder are different. Here is the best way to find out which way to turn it to make it colder. Make sure you hear it running. Take the control knob and listen carefully while you start to turn it in one direction first. Turn it until you hear the unit shut off. If you turn it all the way to the left and it keeps running, turn it all the way to the right until it stops running. Once you know which way it stops running when you turn it, this will tell you that you need to turn it until it comes back on again and runs. This will be the way it turns to get the temperature to get to a colder setting. When you are doing this, do it very slow and give it about 3 minutes in between each time you start to turn it the other way. On mine it has numbers on it. The higher the number lets say from 1 to 8, the colder it gets, but some are the lower the number the colder it gets. So, you want it to shut off, so wait until you hear it running before you turn the knob. You can open the doors and it will make it come on faster. So when it goes off when you turn the control knob, you will no to turn it the other way for it to come on and it will get colder the more you turn it in that direction. Very easy. PS If it doesn't get colder when you find out which way it goes, you may have a bad thermostat. Please let me know. You can put a thermometer inside to watch the temperature
Good Luck,
Shastalaker7
Jun 30, 2010 | Hoover 9.9 cu. ft. / 280 liter Upright...
Temp Control
Hi!!
The higher the number, the colder the setting.
Rate this post, Good Day!!
Apr 26, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
I came home from work and the alarm was going off on the freezer, i unloaded the food and discovered that the dial in the back of the frezer was turn all the way to the left i then turned it all the way to...
Yes, it is a temperature control. You will want to turn the dial back to about the center position and then go higher or lower from there. All the way to the right will probably make the freezer try to be colder than you need and ice cream may be impossible to dip for instance. Also if you are running colder than you need to be the freezer will use much more energy. If you have a thermometer that you can stick in there go for around 0 degrees F
Nov 17, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
After clean, the magic chef chest frezer no linger frezen.
I think in the defrosting process, the evaporator was damaged causing refrigerant leakage. sorry... dont try to repair.. it sucks in moisture
Aug 26, 2009 | Freezers
IT KEEPS FREEZING VERY BD AND SO MUCH O THAT WE
turn 2 lowest setting and if it continues to run u may have a bad thermastat.
Jul 25, 2009 | Belling Freezers
Freezer temperature went from 0 to 20 degrees farenheit and holding.I had the digital readout, alarm, and temp. setting go out 1 year ago and replaced with inside temp. guage. I have a warrnty on the...
If this is a self defrosting freeze,then it is normal to periodically see an elevated reading during a defrost cycle. At 20 degrees, it was probably ready to complete its defrost cycle and come back on to return it to your cold setting.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 25, 2017 | Kenmore Freezers
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezers Logo
62 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
