Question about Toshiba Satellite 2410-S203 Notebook
Only works about 45 minutes .
I recenly purchase a new battery for my HP Compaq Laptop.I only get about an hour of useage when not plugged into electic outlet.
Any ideas to help, please. Thank You
  • 691 Answers
Turn off wifi and anything else you dont need like bluetooth. turn off sounds. also, If you are inferring that this battery gives you less time than the original check it has the same mAh rating and the connections are clean
Posted on Aug 02, 2009
  • 748 Answers
Hello
Depending on the age of the laptop, you should get a very minimu of 2 hours life from the battery. Return it to whomever you purchased it from.
How to extend the battery life of your laptop HP/Compaq pavilion dm4
Tips to increase battry life:
1. Never charge when battery already full.
2. Keep low Brightness.
3. Keep volume medium.
4. Always use headset to hear songs or see films.
5. High graphics games never play on laptops it reduses your lapy's battery life.
6. Never use laptop up to 0% battery power.
7. Close background processes using task manager(these processes not essential but consume battary.
Jun 21, 2013 | HP Pavilion dv6000z Notebook
Tip
Looking for the longest battery life laptop ?
We’ve yet to see a Windows laptop with battery life longer than 5~7 hours, unless we add an extended battery to the system. But when hpand dell launched its new series of laptops last week, one big push wasfor longer battery life.
When you purchase your notebook, charge the battery to 100 percent,discharge it completely, and then fully charge it to 100 percent againto help the battery remember exactly how much electrical charge it canhold. From then on, you’ll never need to completely discharge the laptop battery again, but always make sure when charging it that you let it reach 100 percent. DeHoop told us to “remember to plug in the laptop AC adapter(or dock/port replicator) whenever you get a chance. Most notebookswill recharge quickly.” Salinas had another tip for your batteries:“Keep them cool. Exposure to high temperatures can be a battery’s worstenemy,” he said
Hope the list can give you some help when you purchase a laptop or battery:
Top 5 long battery life for laptop
HP/Compaq Business NoteBook 6715B Battery 6 cells 4400mAh Description:
Type: Li-ion, 6 cells
Voltage: 10.8V
Capacity: 4400mAh
UL certificated cells inside!
Original HP Pavilion dv8000 Battery 8 cells 4400mAh Description:
Voltage: 14.4V
Capacity: 4400mAh
Type: Li-ion, 8 cells
Color: Dark Grey
Dimension:205.40 x 69.80 x 20.90 mm
Status: New and original.
Packing: Plain Box
Dell Inspiron 6000 Battery 9 cells 6600MAH Description:
Type: Li-ion, 9 cells
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
HP/Compaq Pavilion DV6000 Battery 12-cells 8800MAH Description:
Cell Type: Li-ion, 12-cells
Voltage: 10.8V
Capacity: 8800MAH
Dell Inspiron 6400 Battery 9 cells 6600MAH Description:
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
on Feb 24, 2010 | Computers & Internet
Battery problem with HP Compaq Presario V2000 laptop
When batteries fail, they usually lose the cells inside them, which means that the cell is no longer able to function as a holding cell for power and therefore cannot do its job anymore, when a battery fails to hold and refuses charging it is bad and needs to be recycled. The flashing is telling you to purchase a new battery. The larger the number of cells in the battery, the longer and better it will perfrom,,RE: 6 cell, 9 cell, 12 cell.
Jan 13, 2010 | HP Compaq Presario V2000 Notebook
How to change the battery
hi
its so simple...
  1. Step 1 Purchase a new battery. Refer to your laptop owner's manual to determine the type of battery you need. Compatible laptop batteries can be purchased from computer parts dealers, the laptop manufacturer, or an online auction.
  2. Step 2 Turn your laptop over and locate the battery compartment. Release the lock/latch and slide out the old battery. Refer to your owner's manual if necessary.
  3. Step 3 Install the new battery by first aligning its receptor pins with the pins in the battery compartment. Push down on the opposite end to snap the battery in place. Secure the lock/latch mechanism by sliding it back to the original position.
  4. Step 4 Plug your laptop into an electrical outlet to charge the new battery. It usually takes about 24 hours to complete the first charge. Subsequent charges will only take a few hours.
please rate me...
thank you
Sep 18, 2009 | HP Compaq Presario V2000 Notebook
Help! Compaq Laptop "Plugged in,Battery Not Charging"
I had the same problem on my CQ60. HP battery test showed one or more cells not working. After spending about 2 hours talking to some guy in India,or somewhere, he came to the conclusion that my battery was bad. HP sent me a new battery, which fixed the problem.
kenbun
Sep 11, 2009 | Compaq Presario CQ60-220US PC Laptop
Battery does not charge
Will the old battery (that you are replacing) charge up at all? If the old battery charges but the new battery will not, then it's likely a bad replacement battery.
To rule out the possibility of a corrupted battery meter inside of windows, you may wish to leave the laptop on battery power only, until it dies. A 5% charge will usually only grant you about 20 minutes of laptop life maximum. Since you left it charging all night, you should get a few hours of life before it dies. If you get a few hours of life, the battery meter software is corrupted.
Most likely though, the replacement battery is bad.
Sep 02, 2009 | HP Compaq Evo n610c Notebook
Compaq Presario v2000 notebook reduced battery life
you may try:
1) check the battery alarm at windows power managment, to set 5-10% alarm level.
2) discharge the battery to the empty then charge longer time, you need monitoring how long it charged (see charge lights change), need to change new one if charging time much less then before(less then 10-20 minutes)..
3) plug-in AC adapter monitoring charging current,
this step you need a current meter to make a series connection in the circuite, the battery is over life cycle if the current less then 500mA.
May 02, 2009 | Computers & Internet
The Battery in my Hp Laptop Pavilion ze4900 is
using the wrong ac adapter the e500 adapter is not the same voltage or watts!
Feb 26, 2009 | HP Computers & Internet
Hi, My Compaq is getting hot quite quickly after being switched on (about half and hour to 45 minutes, and then shuts down and won't turn on again for about ten minutes. It's only about five months old, is...
you could as well have a bd battery. Check the compaq web-site and type in ur model of computer then try to check if there is any call back on your battery. if not it might be just yours. Look online to see how much a new one is. it also could be your fan. it might not be working. do you hear some kind of air or fan working? it might be to your advantage to replace both battery and fan or just the fan.
lease kindly leave me feedback!
Jan 20, 2009 | HP Pavilion dv8000z Notebook
Compaq laptop Evo N410c Battery charging
Hi
First remove the battery and run only on the adapter... If it works fine then there is no problem with adapter...... Charge the battery continuously for 4 hours without seeing the percentage of charging and remove the adapter..... If the laptop runs on battery for 45 mins then it might be the problem with drivers..... Go to device manager and reinstall the drivers if it is less than 45 mins.... Reinstall the drivers either ways...... If still the problem persists.... Go to HP.com and and select software and driver downloads and give the product number.... select the OS... Select HP battery check.... Download the file (sp32299.exe) and click save.... Save file onto the desktop and close the site..... Run the exe file.... If it passes the battery is fine... If fails replace the battery....
The steps might be longer..... But i can assure that it will work
Oct 22, 2007 | HP Compaq Evo n610c Notebook
Toshiba Satellite 2410-S203 Notebook Logo
95 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
