BLU R1 HD cell phone
SOURCE: Cell phone will only say rescue mode
Dear Kitten 17
I had this problem my self and I had to reinsert the SIM card Properly. Please check this first, it is easy and if it is the reason that is happening then its a 2 minute fix.
Otherwise if the phone is still on warranty please hand it in to a repair service center as it probably suffered shock damage to an Integrated Circuit within the motherboard.
Regards
SOURCE: car kit mode???
The Car Kit message is usually caused by corrosion in your charging port. Yes, holding * may revive the phone, but your best bet is to get some contact cleaner and a toothbrush and clean out your charging port.
SOURCE: My phone is in "car Kit" mode
OKAY THERE IS WHAT YOU DO:
1.GET A PIN OR NEEDLE POINT.
2.LOOK AT THE CHARGER PORT
3YOU WILL SEE THE COILS OR THE PRONGS THAT YOUR CHARGER CONNECTS TOO
4 NEXT TO THE COILS, EITHER ON LEFT SIDE OR RIGHT SIDE THERE IS A SMALL BUTTON. LIKE A CIRCLE LOOKING THING. IF YOU CAN NOT SEE IT NO BIG DEAL
5. STICK YOUR PIN INSIDE PUSH THE LITTLE CIRCLE. IF YOU DON SEE THE CIRCLE PUSH IT ON BOTH SIDE
6. YOUR DONE.
SOURCE: Sync SGH-A707 Samsung cell phone problem
Your phone needs the main ribbon, that is the cable that connects to the side of the with the battery to the side of the phone with the screen.
NB: a professional technician has to fix this.
br,
www.phonefreedomjamaica.net
