Question about Samsung CLX 3160fn All-In-One Printer
Black ink is so light I can barely see it. Replaced cartridge and nothing helps.
  • 1 more comment
  • Virgoesq Aug 02, 2009
    Thanks. It's not in draft mode. I double checked.
    I don't know the difference between toner and cartridge. Not sure how I would clean that.
    I have replaced ink cartridge numerous times and the problem persists. Thanks.
    Do you mean remove the cartridge and clean in the narrow cylinder-type hole underneath the round cartridge? Or where it connects at the back - straight in front of me? I tried cleaning both and it seems to have helped a little, but the problem is still there. Maybe I'm not cleaning the right place.
    I am experiencing a problem with the black ink on my CLX 3160FN Samsung. The ink is so faded that, no matter what I do, it pales in comparison to the blue, red, yellow, etc. I have the paper in NORMAL (not draft) mode. I have cleaned the connection between the cartridge and toner transfer area. I am not receiving any error messages about my transfer belt, but suspect this might have something to do with it. Also, I have replaced the cartridge multiple times and that doesn't help. I let the new cartridge run for 15 prints and it still didn't make a difference. Help!
You almost certainly need to replace the drum, which runs about $95 and is guaranteed for a year. It's considered a consumable, just as the toner is, but so far I've only found them online...I've been told by Office Depot that the drums that come with the machines aren't of as good a quality (and don't last as long) as the one you'll buy after that
Posted on Aug 02, 2009
    President:
  • 670 Answers
This is a very common problem with the Samsung clx-3160 and clp-300. Buying a new drum will fix it, until the developer blades get dirty.
If your printer looks like this:
Then you need to clean the developer blades. In the image above it is the black blade that need to be cleaned. If there are streaking on any other color, then then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade.Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit.
Posted on Dec 23, 2009
  • 11,896 Answers
Try cleaning the contacts where cartridge meets toner. Sometimes toner needs to be replaced.
Read the manual..... sound like you've managed to set 'draft' printing as
the default by accident
  • Nate Stansfield
    Nate Stansfield Aug 02, 2009
    The connections where the cartridge connect to the rail. clean it with rubbing alcohol and cotton swab.
2 Suggested Answers
  • 406 Answers
SOURCE: CLX-3160FN black ink problem
This is the problem of black developer in the imaging unit. This may be replaced by Authorised service center.
Best Regards,
Originally the black ink would not print. replaced, primed, cleaned. nothing, the same problem, no black ink. Now I can't get the cartridge light to quite blinking. It is not steady orange, but a...
First off, if you touched the metal contacts on the printer or cartridge, you could damage or leave a film on the contact surface. Take it out of the printer, with a qtip dip in rubbing alcohol, squeeze out access, rub surfaces, air dry, and reinsert again. If still no ink, turn the print end up under the very hot water tap and run for 2 minutes. Dry and replace. It may do the trick.
Mar 01, 2014 | HP DesignJet 450c InkJet Printer
Best Regards,
Aug 02, 2009 | Samsung CLX 3160fn All-In-One Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Lined printing in black ink
We get that problem w/ refilled cartridges. There is probably a very big clog in the nozzles. If you're using virgin OEM cartridges then you should complain about it. But if its refilled cartridges you will have to do a lot of work on it to clear up the nozzles. I don't suggest you do it manually as it will take a day or so just for one cartridge. Hope this helps.
Aug 22, 2008 | HP OfficeJet 6110xi All-In-One Thermal...
Ink cartridge unit will not move to replace
Printer has pads for excess ink, once pads are full this happens.
Pads will need to be replaced
Jun 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Cannon multipass 390 print problems
I have the exact same problem, cleaned heads, replaced cartridge, nothing prints, no ink at all no colors or black.
May 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Acts like it is printing but nothing comes on the paper
some cartridges comes with deffects, replace with new one or reclaim warranty to your dealer
Mar 08, 2008 | HP PSC 1410 All-In-One InkJet Printer
Ink replacement has not helped print
Sounds like a damaged or dirty flex cable to the print heads. If those tiny contacts go bad, nothing will print properly. Check the cartridge and socket area for any dirt or dis-coloration. The connections can be cleaned with contact cleaner (from radio shack), and then dried with isopropl alcohol (use the purest you can find).
Jan 03, 2008 | Lexmark X1240 All-In-One InkJet Printer
Samsung CLX 3160fn All-In-One Printer Logo
352 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
