Question about Motorola Mobility SLVR L7 Cellular Phone
My motorola slvr battery signal does not blink when being charged anymore... What does this mean?
  • 1 more comment
  • siahkyaty Aug 02, 2009
    Naw the battery is new. Let me go into detail on the troubles with my phone....
    Alright a couple months ago the charger i bought stopped working... My brother tried to fix the charger and when i plugged the phone up the phone read "UNABLE TO CHARGE" after that i bought a new charger, and the phone would not even attempt to charge at all...
    I started to use a completely different L7 phone to charge the battery and I would just switch the battery once it was completely charged back and fourth to my regular phone...
    After that old battery was warped and clearly needed to be replaced i went and bought a new one. The lady used a charger at the metro store and it suddenly started charging, but when i used my charger at home it again wouldn't charge at all...
    So then i stuck a pen inside of the phone charger slot pushed up, and tried to charge the phone again... IT SUDDENLY STARTED CHARGING and everything was cool.
    Just now i tried to charge my phone and when i put the charger in it wouldn't charge so i stuck the pen in again, and it said charging... but the signal would not blink...
    So does that mean the phone is just busted?
    Damn... I just put the battery in a different phone and Its charging like its suppose to. The signal is blinking and all... So the charge slot or whatever is indeed busted... UGH. But if i continue to charge the battery on that phone will it blow up my battery?
    Alright, THANK YOU!!!!!!!!
    Brigadier General:
  • 4,090 Answers
It could mean you have to replace the battery?
Posted on Aug 02, 2009
  • dennis bullard Aug 02, 2009
    Well I would think so, it is most likely a dry joint on the board and when you push the pen in (kludge!) it engages but not sufficiently to allow a flow. It may also have taken a resisitor out that regulates the input.
    However let me run this by you, if the battery became totally flattened it may not blink until a reasonable amount of power has been accumulated, it then goes into trickle mode ( blink) If you are sure the battery is not completely flat having done a charge on another unit then think dry joint or damaged charge pin
    Not as long as the rating of amps is the same and the pin polarity is the same Most chargers have a pic showing whether its center + ve or Neg . Watch that the battery dosnt overheat on the otjher charger if its not the riht rating it will cook it.
Overheating L7
It can be due to the battery getting warm while the phone is used continuously or when the charger is connected for charging the battery. It is possible that a poor battery can heat up when the current is drained.
If the phone by itselt is heating it can also be due to shunting due to poor signal strength or connectivity as the phone HUNTS for the signal therby working with a higher output.
Nov 01, 2010 | Motorola Mobility SLVR L7 Cellular Phone
My motorola slvr L7c will not charge.
try removing the battery and make sure it's in properly and try again
Jun 22, 2009 | Motorola Mobility SLVR L7 Cellular Phone
I have a Motorola V710, it will not power on but the screen blinks when plugged in to charge, what's wrong?
The batery may not be holding a charge anymore, try removing the battery and clean the contact's, if that do'es not work the battery may need to be replaced.
Apr 18, 2009 | Motorola Mobility V710
My motorola slvr L7 turns off and on automatically
bad battery over or under charged. never talk or web browes when chargeing only downloading is supported for the power chipset. if this persist then you need a genuine MOTOROLA CHARGER!!!! 6pin
Mar 12, 2009 | Motorola Mobility SLVR L7 Cellular Phone
MY MOTOROLA SLVR WONT TURN ON
Maybe your battery needs to be charged. If you tried that, then the battery is probably dead and you have to buy a new one. Maybe the battery is old too.
Dec 30, 2008 | Cell Phones
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Battery not holding the charge
freakie - so after all that why have you not try using a new charger.
Guest - well it should not but remember that if you are not getting a strong enough signal the battery will use up more trying to pull a signal....so maybe you spots are not strong signal areas but if that is not the so then change the battery if the same problem occur then have the phone exchange but hopefully you have already notify the store you purchased the mobile from about this issue., so this would make it much easier for you to have an exchanged.
Mar 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorla Slvr L7 Won't hold charge
It depends on how much talking your doing. The Slvr is known for its low talk-time battery power. My slvr would last about 3 to 4 days on a charge, unless i was talking on it a lot. sometimes i would be charging it every other day. So it really all depends on the talk-time. Invest in a car charger for sure.
Dec 24, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola slvr unable to power on
wait until the phones battry get fully chrged working with a fully drained battery is bad to phone as wellas battery itself
Dec 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola RAZR V3 No signal (bars)
I had the same problem with my phone- i got a cheap generic battery to replace the old one (which wasn't holding a charge for a full day, at that) and then i lost all signal, basically. I tried what scm_pa said he did - charged my old battery up, with the phone off, till the charge was complete- turned the phone on, and voila, reception!
Oct 03, 2007 | Motorola Mobility RAZR V3
Motorola Mobility SLVR L7 Cellular Phone Logo
170 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
