Question about Dryers
We have a kenmore 70 series electric dryer, and we have a three prong receptacle, but the plug is 4 prong. What type of adapter do we need?
  • 5,911 Answers
According to the National Electrical Code, as of 2000 all newer homes are required to have a 4-prong receptacle for all 220VAC appliances. However, if your home already had a pre-existing 3 prong outlet, you shouldn't have to upgrade to a 4 prong. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the neutral (WHITE) and green (GROUND) wires are termnated. In a 4 wire configuration, the neutral and ground are independent of each other. In a 3 wire configuration these two wires are terminated together. The instructions to convert a 4-prong appliance to a 3-prong are at the bottom of the page in the link I provided.
NOTE: If this is a new dryer, keep in mind, some REQUIRE a 4-prong plug even if you have a pre-existing 3 prong outlet. Read through your installation instructions that came with the appliance if in doubt. If this is the case, you will need to have a 4 wire outlet installed by a certified electrician.
If you have questions, please let me know. I hope this helps you.
Posted on Aug 02, 2009
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
Feb 16, 2014 | Frigidaire Washing Machines
Frigadare Dryer
Basic Dryer Electrical
Electric dryers in the US operate on two 110 volt A/C circuits. The two 110 volt circuits combine to deliver 220 volts A/C to the dryer heater. 2-dryer-plugs.gifSee the basic dryer heat circuit. The dryer motor operates on 110volts A/C. Dryer receptacles have an L-shaped neutral post. You can check the voltage to your dryer by slightly sliding the cord out of the receptacle and using the leads from a multi meter to check for voltage on the blades of the cord that slide into the receptacle. Between the left and the right blades you should read 220 volts. Between the left or right blade to the center blade (the L-shaped blade) you should read 110 volts AC. The 4-post receptacle above has the L-shaped neutral and a seperate ground. It requires a 4 wire cord and the ground wire is isolated from the neutral on the dryer.
Technicians check for voltage when the dryer is attempting to start or not heating for a very specific reason. Checking for voltage without the dryer plugged in does not tell the full story. A dryer heater uses 220 Volts and draws about 20 amps when it is heating. Checking for voltage from L1 to L 2 on a defective circuit may show 220 volts but when the heater kicks in and starts to draw 20 amps the voltage may drop off to 0 volts. Imagine the wiring to your dryer was stranded wire. Stranded wire is composed of a number of small-gauge wires bundled together to make a larger wire. What if all but one of those stands were cut and only one small wire was completing the circuit? Reading voltage at the receptacle without the dryer plugged in you would read 220 volts from L 1 to L 2. However with the dryer plugged in and the heater attempting to draw a heavy current, the electrons (current flow) would be dammed up behind the cut and only a small amount of current would pass through the wire. Certainly not enough to make the heater heat. There are a lot of things that can cause a partial circuit but the result is the same as the stranded wire example. Many a heater or dryer motor has been changed needlessly because of a loose connection in the fuse box / circuit panel or some other dryer electrical circuit problem.
Aug 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
I was given a used kenmore series 80 electric dryer, unfortunately the plug doesnt fit into our 3 prong receptacle. What style no.# receptacle would I need. the last one purchased look correct but the...
usually 30 amp and there are several different configuations, they are available at hardware stores, and very east to switch over at the back of dryer. draw up what it looks like and take to hardware store and they should be able to set you up
Oct 17, 2009 | Kenmore 62602 Electric Dryer
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Elkectric dryer won't start
to put it kindly depending on way you connected wires unit could be damaged,replace pigtail with three wire and outlet to original.outlet wires should be black,red and white. turn breaker off attach white to middle and red,black to sides,"either side is fine".Attach dryer pigtail in same manner with white on white and if plug in and turn breaker on.If there is no operation at this point dryer possibly damaged from previous wiring.Just remember be safe when working with electrical and ask before trying to change things that aren't the same.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
I need help in changing the 4 prong to a 3 prong cord
It would be a better and safer idea to change the receptacle from a three prong to a four prong. You would also be in compliance with the electrical code. That being said, here is the info you will need to go either way.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Apr 03, 2009 | Kenmore 84832 Electric Dryer
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
I have a kenmore dryer model 11060212990, and the plug has three prongs, but the wall socket is a four prong. what do i need to do?
You will need to purchase a 4-prong power cord and convert the appliance to meet the needs of the wall receptacle. This is a requirement of the National Electric Code in homes that have the 4-prong receptacle. The following link explains how to convert your dryer cord from a 3-prong to a 4-prong:
These rules apply to the conversion of electric ranges, as well. Read through the link thoroughly and let me know if you have questions. If you require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 29, 2009 | Dryers
What type of power cord ( 3 or 4 prong) for an electric dryer
Hello markdraghi,
I assume ( but don't know) that you are replacing an existing dryer... That said, then you need to match the cord ( 3 prong or 4 prong) with what you currently have for a receptacle. A 3 prong uses two hot feeds ( red and black) and a Neutral ( white). A 4 prong uses the same as the 3 prong but also includes a Green wire for Ground. Get back to me if you need wiring details or if I have NOT answered your question. Hpe this helps.
Regards,
Rick
Jan 04, 2009 | GE DBSR453EBWW Electric Dryer
Dryers Logo
227 people viewed this question
Top Dryers Experts
