Question about Autodesk AutoCAD LT 98 w/ Electrical Library Full Version for PC
Radio problems
I have 98 firebird,has a sattelite radio in it ,, some times it works . when it doesnt work the windows wont go up or down , they are electric;it has a little red light on dash ,, when that doesnt lite up .. i un plugged the radio , thought it was that ,, but still doesnt work ,, any ideas thanks
It was in the wireing harnass thanks
Posted on Aug 03, 2009
98 firebird, all dash lights quit working while i was driving it, and when i killed it it wont start back up
Sounds as if you may have burnt out a fusible link. They are usually located in the + side of circuits near the battery or near the starter motor. You can test them with a voltmeter.
Feb 28, 2014 | 1998 Pontiac Firebird
2000 pontiac firebird windows sometimes wont go down or up and its not the window motors it has an alarm installed if u hit the dash sometimes it helps
With the security system I have been told you can get a sensor that you plug into your security system that came standard with the car. THis system is located under the plastic that covers your speakers on the passenger side in the back. If you unplug the sensor and then pick up a relay from radio shack it acts the same as reading your key that is in your car and will allow you to roll the windows up or down when the key is in the ignition
Mar 26, 2011 | 2000 Pontiac Firebird
When i start my 01 firebird the radio wont come on and the windows dont work, after about 30 seconds they start to work. 2 days ago the power antenna just kept going up and down about 7 times. it seems to...
With our 2000 Firebird the Door locks also didn't work. A couple of solder joints became loos on a BCM module located under the glove box area inside a plastic case we had to remove. All's good now on ours after resoldering the locations I found on another site.
http://www.fbodyonline.com/how-to-fix-intermittent-windows-radio-and-locks/
Good Luck
May 27, 2010 | 2001 Pontiac Firebird
Wont work on windows 7 why doesnt windows 7 support plug n play
This particular camera works well under everything from Windows 98 - Vista 32-bit. However, under Windows 7 64-bit, it fails to work due to there being no drivers for it. It is a very adequate camera, well-designed and could be used for many years to come if current/working drivers were available.
Feb 21, 2010 | Intel Deluxe PC Camera CS330 Webcam
My windows and my radio stop workig at the same time!!
Sounds like you could have an issue with a connector going into your BCM or possibly your BCM itself. There is a fusible link that comes off the BCM and it goes to your radio and power windows. Off hand i believe its circuit 75 if you have a wiring diagram and possibly a dark blue wire. On the passenger side kicker panel there is your BCM you can try to wiggle the connector and see if that is it or inside the BCM the solder joints could be going and in that case your screwed.
Jun 11, 2009 | 1998 Pontiac Firebird
98 escort radio wont turn on
sounds like a bad install. disconnect fuse to radio amp or remove power from amp as to not drain the battery. have a pro check out your security sys. better safe than smoke!
Mar 29, 2009 | 1998 Ford Escort
Power Windows & Stereo cut out, 98 Camaro
Lol i share your problem. I found that holding the lock button down and hittin the DRIVER window button a few times help, some say just hittin the power lock a few times work by its self.
Mar 14, 2009 | 1998 Chevrolet Camaro
1998 PONTIAC POWER WINDOW PROBLEMS
Double check all your fuses and and wires in connection with your power windows. Unfortunately though pontiacs are notorious for the power window motor regulators to go out, my buddy had 99 firebird and both windows had the same problem, and I previously owned a 98 sunfire and both window motors went out within the same week.
Jan 30, 2009 | 1998 Pontiac Firebird
Autodesk AutoCAD LT 98 w/ Electrical Library Full Version for PC Logo
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
