Question about Garmin nuvi 265 Car GPS Receiver
I have only used it maybe 10 times. Suddenly it sounded like someone talking and it stopped working. I know nothing about it and of course lost all papers.I think i pushed something wrong :(
    Scholar:
  • 32 Answers
There may be a reset button on the back of the device under the flip up antenna. try pushing the reset button and it should reset the device back to the original factory settings. Sounds like your device froze up or got muted. If you still have no luck, call Garmin at:1-800-800-1020 . I hope the reset works for you, if not maybe Garmin could give you a few suggestions. Good Luck!
Posted on Aug 02, 2009
The reverse button suddenly stopped working. Are there any trouble shooting tips?
Maybe... but if I don't know what you are talking about, it's quite hard to help you, Start by specifying what device are you usind, make and model, and MAYBE, no positive promise, someone might find some troubleshooting tips
May 29, 2015 | Sewing Machines
2006 Kia Sportage
He guess at the brake switch sensor. Sounded like the ABS switch to me. I would see if he could take the 486 off of the 1890. Also check for recalls and/or warranty, maybe it's a known and covered issue he's not investigating.
Mar 12, 2014 | Cars & Trucks
When i start using my laptop , suddenly white screen and forcible shutdown,.
It sounds like it's overheating, make sure the airways are clear of dust and listen for the sound of the fan inside, this could have failed..
if the processor overheats it automatically cuts out and what you describe is exactly that..
good luck !
Mar 30, 2017 | Computers & Internet
Keeway hurricane 50 .the electricty went off suddenly
Hello and happy thanksgiving from the USA.
I would suspect that you have a defective igntion switch, the igntion switch is what powers up all of the electrical system when you turn the key to run, the contacts can get burnt or the connector or both. The switch is under/behind the ignition key cylinder which operates the switch or course.
Nov 24, 2011 | 2008 Keeway Hurricane 50
My Pure Evoke 2 Dab radio has stopped working, it has power but can't get sound stations or anything ...what do i do?
I've got the same problem, from working perfectly to suddenly nothing. "No stations available". Please let me know if you get an answer.
Sep 02, 2010 | Audio Players & Recorders
Viore tv sound but no picture
the sound suddenly stopped working on my Viore 42" plasma.
Aug 17, 2010 | Toymax Viore 42 in. Plasma TV
1tb Western Digital hard drive stopped working suddenly, no light
If the hard drive does not even turn on, then check its power supply. Maybe the power supply went bad; it should be a standard 12V 3.5A power supply.
Even if the power supply is working, chances are good that your data are still there, because the unit not turning on means that the internal enclosure, not the disk electronics, got messed up. It's unlikely that BOTH enclosure electronics AND disk electronics went south together, unless you got a lightning strike at short distance (less than 60 feet, say). You'll need to open the enclosure, extract the drive and connect it to another compatible enclosure (most USB/eSATA enclosures with the same EIDE or SATA connector as your WD will do) in order to override the fritzed enclosure electronics and connect directly to the hard disk. Once you do, your data will be there. If the disk crashed last time it turned on, maybe you'll need to run disk checker and expect to lose a file or two.
On the other hand, if the drive does turn on when powered, and the PC "just" doesn't see it, chances are proportionately bad for your data: you'll need to send the disk to a data recovery service, which can be quite costly.
Nov 03, 2009 | Western Digital My Book Essential 1TB...
Horn not working
sounds like a prob in the connection to your steering wheel. the steering wheel has a special connection that allows all the functions on it to be connected via a rotating connection (did i say connection enough...? lol) i dont know the terminology behind it, but that rotating thing is what lets you turn the wheel. Otherwise, regular connections with simple wires would bunch up everytime you turn the wheel. It sounds like something came loose or just lost connection in there..
sorry so vague. im a novice at this.
happy hunting
Sep 09, 2008 | 2004 BMW 3 Series
Cranks but wont turn over
you know. i took it to a mechanic and actually.... The timing belt cut the Crank Shaft Censor... So it was the crank shaft censor again. The wires were routed wrong from the first mechanic that "fixed" the car.
Aug 01, 2008 | 2000 Hyundai Sonata
Paper will not feed properly/one side of paper not feeding in straight
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Garmin nuvi 265 Car GPS Receiver Logo
178 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
